Question about Smooth trip ST-LS7004-B Digital Luggage Scale
How to reset digital smooth trip scale - Smooth trip ST-LS7004-B Digital Luggage Scale
Just replaced battery - trying to reset the scale to 0.0
PDF]Instructions for use of ThinnerĀ® Bathroom Scales
www.conairscales.com/catalog.php?product_id=428&ib=en
Scales for the way you liveĀ® ... Tap on the scale and wait until "0.0" appears; press Set button, ... button to change the goal weight if necessary, once the ... NOTE: 1. When the scale traps zero error, "Err" will show. Please try again. 2.
How to Set a Digital Health O Meter Scale to 0.0 - Livestrong ...
www.livestrong.com > Weight Management
Aug 12, 2015 - The scale may not register at 0.0 when starting out... ... The Differences Between Balance Beam Scales & Electronic Scales ... 10 High-Tech Health Tools toTry This Year; Are You in Need of a Digital Detox? How to Start Doing Parkour. References. Healthometer.com: FAQs; "Health o meter User Manual" .
Jan 05, 2016 | Health & Beauty
What mean "error 3"
Try takign the battery out the reinstalling it.
Jun 29, 2014 | Smooth trip ST-LS7004-B Digital Luggage...
Scale wont zero
Try to remove the battery and reinstall it after 5 secunds.
Be sure that the battery is ok.
Apr 17, 2014 | Smooth trip ST-LS7004-B Digital Luggage...
Operating instructions for Volt -100 pocket scale
If you don't have the measured weights that sometimes come with scales or can be purchased individually, I'd recommend using a United States nickel/5 cent coin. They are supposedly an exact 5 g's each, and a Volt-100 scale requires 100 g's for recalibration. Therefore, you can recalibrate your scale using 20 nickels. I also use a Volt-100 and so far this has worked for me exactly; the most it's ever been off is .02 g, which is basically nothing.
What you do is remove your batteries, (I'd replace them with brand new ones if you have the option) then place the scale on a completely smooth, perfectly level, flat surface. Power the scale on, make sure it is reading 0.00, hold the M (mode) button until CAL comes on the screen, release the button for a quick second, then press it again one more time (quickly, don't hold this time), and then wait until "100.00 g" is flashing on the screen. Then you're going to place your 20 nickels on the scale as smoothly and with as little jostling or movement as possible. After a moment, the screen should read out "PASS". You then power the scale off (don't weigh anything before turning it off as it can possibly adjust the calibration you just set or weigh out heavily or light) and to test out your newly calibrated scale, turn it back on and weigh one nickel. It should be exactly 5 g's, with no more than a .02 digression in either direction if done properly. Good luck!
Jul 07, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Scale keeps showing lo no weight
Try taking the battery out and putting it back in, also there should be a small reset button. You will need a toothpick to push the reset button. Allow time for the scale to reset before stepping on it.
Apr 19, 2011 | Homedics Digital Scale
Need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Aug 25, 2009 | Health & Beauty
Need to reset scale weight
You have probably set your scale to kilogram and not pounds. There should be a button to set this underneath the scale or even a reset button to reset the scale to its original settings.
Jul 08, 2009 | Homedics Glass Top LCD Digital Lithium...
Smooth trip ST-LS7004-B Digital Luggage Scale Logo
26 people viewed this question
Top Smooth trip Luggage & Travel Experts
ray gallant
Tom Chichester
Dave braun
Dave braun
Are you a Smooth trip Luggage and Travel Expert? Answer questions, earn points and help others
