Question about Samsung Washing Machines
Squeaky nOISE SOUNds like a bIRD
Sometimes has a squeak SOUNds like a bIRD, IS IT A Belt?
3 Suggested Answers
SOURCE: Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Posted on Oct 14, 2008
  • 96 Answers
SOURCE: the squeaking noise is when the washer is spinng
no belts in a washer just a tramsmision it could be going out
Posted on Dec 13, 2009
How do I fix a squeaky belt on a minivan?
Post question is automotive section?
Is belt squealing? or is there a squeaky noise?
Squealing would denote belt slippage... belt might be loose, apply more belt tension at idler pulley (if possible). Consider trying a spray-on 'anti-slip" compound.
Squeaky noise could mean a bad pulley bearing.
Oct 13, 2014 | Dryers
My 2005 trailblazer makes a bird chirping noise. Exactly like birds. My mechanic replaced the belt but it is still making the noise.
If is a serpentine belt, take it out and check the belt tensioner. some of them have a screw that allows for tightening/loosing the belt. Sometimes it looses some bearings and it could chirp.
May 20, 2014 | 2005 Chevrolet Trailblazer Ext
Squeaky noises under the hood
IT COULD BE AN IDLER, TENSIONER, OR THE BELT SLIPPING, THESE ARE SEALED YOU CAN'T LUBE THEM. IT SOUNDS LIKE THE BELT IS SLIPPING, BUT IT COULD BE SLIPPING BECAUSE OF A FAULTY IDLER\TENSIONER. REMOVE THE BELT, MAKE SURE ENGINE IS SHUT OFF, AND YOU HAVE THE KEYS, ROTATE ALL THE PULLEY'S AND THE ALTERNATOR PULLEY THEY SHOULD ROTATE FREELY AND RUN TRUE, AND NO ROUGH FEEL TO THEM, OR THE TENSION COULD BE TOO WEEK TO KEEP THE BELT TIGHT.
Jun 09, 2013 | 1996 Oldsmobile Bravada
97 plymouth vourger new belt still squeeks
It sounds like one of your pulleys may be having bearing issues, one way to check this is to go to the parts store and buy some "belt dressing" it is a spray that stops belt squeak. Find a safe spot where you can spray the belt while its moving and only spray the belt. If the belt stops squeaking its just a squeaky belt. If it keeps squeaking then you may have one of your pulleys going bad.
Sometimes pulleys will squeak too if they are just not very lubricated. If the belt dressing works you are good to go, if it doesn't work, go ahead and give the belt area a good spray down avoiding your electrical components. Thanks.
Mar 20, 2011 | Plymouth Grand Voyager Cars & Trucks
My dryer is squeaky. it's a GE model number DVL223EYOWW. how do I fix a squeaky dryer?
It depends on what is making the squeaking noise. Could be drum bearing, drum slides, tensioner pulley, pr even the leveling legs sometimes squeak.
Jan 10, 2010 | GE Dryers
Noise from engine sounds like birds under bonnet, also having problems with passenger door locking when i lock car up
LIKE A SQUEAKING NOISE? MAYBE UR DRIVE BELT OR SOMETYPE OF PULLEY ISSUE. SPREAD SOME TYPE OF SILICONE SPRAY ON THE BELT SEE IF IT GOES AWAY. AND IF YOU DOOR LOCK IS JUMPING WHEN LOCKING YOU NEED A NEW ONE. COMMON PROBLEM ON C CLASS
May 04, 2009 | 2004 Mercedes-Benz C-Class
Squeaky noise when turning
Check your power steering fluid level
Feb 14, 2009 | 1992 Daihatsu Charade
Squeaky noise from serpentine belt
Replace the serpentine belt tensioner. Expect to pay approx $150.00 if installed by a mechanic.
Dec 28, 2008 | 2003 Toyota Corolla
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
