Question about Toshiba 37CV510U 37 in. LCD HDTV
Toshiba 42hl167 goes black
TV goes black after a few min. checked the video connection and the pic maintains. On the I connection we loose the pic
4 Suggested Answers
  • 15 Answers
SOURCE: goes on and off on and off permantly
your backlight is going out.. get it replaced
Posted on Feb 01, 2009
  • 113 Answers
SOURCE: screen goes blank on toshiba 42hl167. sound still
your tv's pictures tube are creating the problem. contact with the tv brand customer services center for the repairment of your tv
Posted on Jan 06, 2011
dduncan774
  • 760 Answers
SOURCE: i have a toshiba model
You need to replace your T-com board. Not very expensive.
Posted on May 19, 2011
I have a 42hl167 led tv it works for 10 mins then sreen goes black but tv stays on so what board do i need to change
T'Con board fault. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 25, 2015 | Televison & Video
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
My 17 yr old sony triniton goes on after about 5 or so min. the picture is great then the screen goes black (audio fine) for about 4 seconds then the pic is back for about five min then the same thing...
U have a soldering iron,a roll of solder and can do a basic soldering work too?Yes,take the tv aparts.Tv have a cold sodering video board,that the board where it is connected to the CRT-(tv tube).Resoldering the sock pins of the video board that connected to the tv CRT-(tv tube).The tv picture,will be stable and work again as soldering work it is done and the tv have to a good connections between the tv video board and connected to the CRT-(tv tube) again.
May 24, 2011 | Sony Televison & Video
Screen goes blank on toshiba 42hl167. sound still works, and turning the tv off for a few minutes restores the picture.
Jan 06, 2011 | Toshiba 42HL167 42 in. LCD Television
42" toshiba regza tv hdmi inputs location
Download the manual below it will tell you all. Its on page 12,it sorta on the Right hand side down bottom, it IS marked. http://www.tacp.toshiba.com/tacpassets-images/models/42HL167/docs/52hl167_e_final.pdf
Mar 13, 2010 | Toshiba 42HL167 42 in. LCD Television
Toshiba lcd tv flickers after being on 15 mins.
This is likely a power problem. Have the power brick checked by an electronics tech to see if it is cycling off and on over time. If the power supply is not the problem, you should consider returning it if you can.
Nov 19, 2017 | Toshiba 32HL66 32 in. LCD HDTV
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
No sound on my Toshiba Regza 42HL167
Found this troubleshooting method on the www.Toshiba.com website. Q. My TV has a picture, but there is no audio?
Models: 20DL77, 20HLK67, 26HL47, 32HL17, 37HL17, 42HL17, 26HL37, 32HL37, 20HL67, 26HL67, 32HL67, 37HL67,
42HL167, 42HL67, 47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00128
1. Please check your connections and make sure if you are using COMPOSITE “yellow, white, and red cables”, SVIDEO,
with “white, and red” or Color Stream COMPONENT “green, blue, red, white and red cables,” that the white
and red cables which are used for audio are plugged in securely into the same inputs as the video.
If your connections are secure, the station may have broadcast difficulties. Try a different channel.
2. If you are using the coax cable from the wall, press the “ENTER” button on the middle of the remote. If the
information provided shows that you have SAP selected we will need to change it to STEREO or MONO. To do
this, we will need to press the “MENU” button, and use the RIGHT or LEFT arrow keys to highlight the AUDIO
menu. Next we will need to use the DOWN arrow to select AUDIO SETUP press “ENTER” and then arrow down to
MTS and use the RIGHT arrow to select stereo.
3. If you have a cable box or satellite receiver, please make sure the TV’s volume, as well as the box’s, volume is
turned up sufficiently.
4. The station may have broadcast difficulties. Try another channel.
5. The sound may be muted. Press VOLUME.
6. If you still have problems after following these steps please contact Customer Solutions at 1800-631-3811 Monday
through Friday 8am to 7pm CST. The Toshiba customer service number is 1-800-631-3811. I hope this helps you with your problem.
Jan 06, 2009 | Toshiba 42HL167 42 in. LCD Television
No picture on my television
Found this on the www.toshiba.com website. Q. I have sound and no picture with the TV powered on?
Models: 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL67, 42HL167, 47HL167,
REF:FAQLCD00111
Using the buttons on the TV itself (not the remote control), press the “MENU” button to see if the TV’s MENU appears on
the screen. If the MENU does appear on the screen, verify that all of your video connections are secure on the TV and on
the connected device. Double check that you are connected in the appropriate jacks, check the other inputs of the TV to
see if the video appears on any other input. If you still do not see any video but can access the menu, try to reset the TV
to the factory defaults.
1. To reset all settings to default values:
i. Press the “MENU” button on your remote to open the menu.
ii. From the SETUP menu, highlight INSTALLATION and press “ENTER”. A new set of Installation
menu icons will appear.
iii. Open the SYSTEM STATUS menu, highlight SYSTEM INFORMATION and press “ENTER”.
iv. Press the LEFT or RIGHT arrow to scroll through the menu bar to select FACTORY DEFAULTS.
v. Enter your PIN code (or 0000 if no PIN code has been set).
vi. Highlight YES and press “ENTER”. The TV will turn off automatically after a few seconds. After the
TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
vii. If the MENU does not appear on the screen, try resetting the TV by unplugging the power cord for at
least 3 minutes.
viii. If neither of the above steps resolved your problem, you can get assistance with this problem by
contacting our customer solutions department at 1-800-361-3811 Monday through Friday 8am -7pm
CST I hope this helps you with your problem.
Nov 22, 2008 | Toshiba 42HL167 42 in. LCD Television
Toshiba 37CV510U 37 in. LCD HDTV Logo
19 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
