Question about Coby Televison & Video
Volume for my COBY 32" Television is out to whack.
When i'm watching my cable on the AV source the volume doesn't start until 4, and then it's instantly kinda loud. So basically i like. . . 1 nothing, 2 nothing, 3 nothing, 4 loud as hell. Just now i'm watching a video off my flash drive and the number 1 setting is blaring loud. I tried to find a firmware update but can't find one, and none of the sound setting changes anything. The model number is TFDVD3295
    Top Expert:
  • Coby Master
  • 12,962 Answers
Your volume control/circuits are fubar. Coby is outta business so getting parts for it might prove next to impossible.
Posted on Jul 20, 2017
5 Suggested Answers
SOURCE: No Audio on 32 Inch LCD Flat Screen
If there's no sound at all, switching channels or not, then you may want to check this out:
http://bobbykolev.blogspot.com/2007/11/insignia-ns-lcd32-32-tv-power-sound.html
Posted on Nov 18, 2007
SOURCE: Sharp Aquos LC-26D4OU HDTV volume adjustment problems
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Posted on Jan 06, 2009
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Posted on Aug 17, 2009
  • 45115 Answers
SOURCE: Coby 32" Television, Volume is messed up.
Coby is apparently out of business.
Posted on Feb 12, 2014
Feb 12, 2014 | Televison & Video
No volume on the cable tv setting?
Does the set have a earphone jack? if dirty or damaged it will cut the TV sound out---about the only other possible reason is a audio problem in the TV itself---if possible put ear up to speaker to see if any sound or buzz is heard.
Nov 30, 2012 | Polaroid FDM-0715 Television
Can't control TV volume after installing Coby DVD765
Unfortunately that is how this unit is designed, you cannot adjust the volume while inputting from an external source, normally the subwoofer would have an AUDIO control, but this one has no knobs, the VOL +/ VOL- on DVD remote only controls while watching a DVD. Only work around for this is if your TV has a 3.5MM headphone jack, you can get a 3.5mm to RCA cable and then your television would be able to control the volume.
May 04, 2010 | Coby DVD765 Theater System
Akai 32" flat pannel making a humming sound?
replace the a/v RCA cables to start with and then if you still have a problem, you have loose connecitions on the a/v board
good luck
caypianan@yahoo.com
Dec 29, 2008 | Akai PDP4225M 42 in. Plasma Television
Reciever turns off
Powering off usually points to issues with speaker setup. You should read pages 42 and 96 of the 606 manual.
Page 42 covers impedence settings. Check your impedence settings for your speakers. The 606 handles speakers from 4 to 16 ohms. There are two impedence settings on the 606 - 4 ohms and 6 ohms. Set to 4 ohms if your speakers are 4 ohms or more but less than 6 ohms. Set to 6 ohms if your speakers sit between 6 and 16 ohms. Incorrect settings can result in the 606 going into power protection after prolonged use or at higher volume.
Page 96 covers testing for unexpected power protection. You should switch off your AV at source and leave for an hour. Disconnect all cables to speakers and other peripherals (TV, DVD et al). After an hour turn on AV and turn volume to MAX, If the AV remains on, turn down volume to min, switch off AV and reconnect all devices. Make sure the speaker cables are properly connected and that no bare wiring is exposed.
Once you have done this switch on the AV and turn to volume to MAX. If the AV stays on then problem solved. If the AV switches off then you should contact your supplier.
Nov 24, 2008 | Onkyo TX-SR606 Receiver
Jun 14, 2008 | Sharp LC-26D43U Television
No Audio
1. Make sure you have connected the cables from audio OUT on the Directv box to the audio IN on TV input 3 and have selected the correct source on the TV.
2. Many sat boxes have an audio volume control. Select the satellite box on the Directv remote and turn up the box's volume.
Hope this helps.:)
Apr 01, 2008 | JVC AV-56WP30 56" Rear Projection...
Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Mar 15, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
44 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
