Canon pc 310 copier will not feed paperit will start but stops
  • 23 Answers
SOURCE: paper will not feed from drawer
Pull the paper tray out of the machine. On the right side underneath you should see a rubber paper feed roller. Clean this off with a slightly damp cloth until it is "squeaky clean". Also, look about to be sure there is nothing blocking the paper path. Sometimes paper gets torn off and left in the machine when clearing a jam.
Posted on Apr 22, 2009
goodgold
  • 389 Answers
SOURCE: Canon PC 941 copier. Paper jam indicated with no paper.
Can be that sensor of the passing of the paper or was broken off flag, or sensor has wedged in position james, more often such can be in block of the fastening, when paper stuck extract. Try its see, this possible behind do. Good luck
Posted on Sep 20, 2009
SOURCE: canon pc 430 feeder problem
You may have to fabricate a new anchor for one end of the spring on the side opposite the control panel. There is a wimpy plastic tab that breaks off here, right next to a black Phillips-head screw. Remove this screw and bend a piece of light wire around it, leaving a small hooked end sticking out for the spring to fasten on to. Replace the screw and install the spring. When you install the spring, it must go over the top of the tiny white plastic wheel, in the U-shaped groove.
This is how I repaired my PC430 several years ago and it's still working fine.
Posted on Nov 08, 2009
  • 329 Answers
SOURCE: Shows paper Jam on Canon 720 PC photo copier
Sounds funny but this model shows a jam when the exposure lite goes bad. Turn on the copier and watch the exposure lamp, should lite up and not flicker. Lamp is still available.
Posted on Nov 19, 2009
SOURCE: I have a Canon PC-6re copier. It is jamming
Use a thin but strong piece of card board (such as the back of a standard yellow pad notebook) and easily force feed it through machine. I had to use this method with our Canon Pixma MP190 printer. Hope this helps, Good luck!!
Posted on Feb 21, 2010
The canon 310 MX is not able to accept new ink cartridges error 6000
if you purchased a canon 310 mx and if it is new..contact the supplier about it.So that they can instruct you how to fix it..Good day
Dec 02, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon imageCLASS D860, starts fine feeds paper through toner end then stops half way through. Sytem shows paper jam, but paper just stops moving. I can open it and lift paper out. paper wt. 20
try cleaning the pick-up and feed rollers with alcohol and see if that takes care of the problem. if it does for a short time that you need to replace those rollers
Feb 19, 2011 | Canon imageCLASS D860 All-In-One Laser...
Canon copier pc 310 will not turn on.
hi there please check the power supply cable and copier inside fuse . let me know the status.
Jan 15, 2011 | Canon MF8180C Color Laser MFC Printer
I need a user manual for the Canon LC 310 fax
You can download your user manual for Canon LC 310 fax fron this link....
http://www.canon.ca/pdf/Canon%20Laser%20Class%20310%20%5B22343%5D%20Lab%20TR%20Reprint.pdf
I am sure this link helpful for you
Thanks
Oct 09, 2009 | Canon LC 310 All-In-One Laser Printer
Does my cannon 310 have a memory for faxes?? if yes how do i access that memory??
Dear sir E2 is problem code is paper miss feed please chck your printer paper feed section. Some time some of paper cut pics paper jum
Aug 11, 2009 | Canon Office Equipment & Supplies
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
May 26, 2009 | Canon PC-420 Copier
Ir 2200 color is cleared from the paper
if the toner is not fused to the paperit is more than likely your upper fuser belt
Nov 17, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon PC 1080 F ADF Problem
call canon for instructions on how to clean feed roller and ADF path; otherwise probably need new seperator pad and possibly paper feed roller
Aug 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Reset mx 310
This really worked with my MX 310:  http://www.fixya.com/support/t378057-reset_ink_levels_canon_mx310
Jul 03, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon MX 310
my suggestion is try to reinstall your printers driver after you reinstall the driver diagnose the printer and try calibrate
Mar 21, 2008 | Office Equipment & Supplies
18 people viewed this question
k24674
