Totaline p474-1050 Unit just quit and screen went blank. Checked circuit breakers but nothing is working
SOURCE: I have a Carrier 38tra048340
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Posted on Jun 23, 2008
  • 148 Answers
SOURCE: RUUD UPGH air/furnace just quit....no response...where to begin?
is the power light on the board lit? IF NOT THE 3 AMP OR 5 AMP FUSE COULD HAVE BLOWN ON THE BOARD
Posted on May 03, 2009
james3751
  • 614 Answers
SOURCE: Heil Max Performance 10 Heat Pump not working
First check to see if you have afloat switch inside the air handler ar underneath the air handler. Its purpose is to shut the outside ac off if the drain stops up. Very common. If this is OK take cover off unit and with screw driver push in the contactor. It is located about the middle of the panel. It has main power at the bottom. If unit comes on you cave a control voltage problem. Meaning something is not allowing 24 volts to the contactor. If your out of Refrigerant the low pressure swich will have it off. Call a service tech. Rusty
Posted on Jun 09, 2009
meBNme
  • 334 Answers
SOURCE: I have a totaline with issues
Replace the batteries first. If that does not fix it, you either have lost 24V from the furnace/airhandler, or the thermostat is bad.
You may get lucky and find that the only problem is a blown 3 or 5 amp fuse on the board. Although that usually indicates a short somewhere in the system.
Posted on Jan 31, 2010
  • 3074 Answers
SOURCE: AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Posted on Jul 23, 2010
What to do when an 8022c wall thermostat screen goes blank - no numbers, just the lines dividing the three areas? Pushing reset does nothing.
Pop the cover off and check the battery. Replace if necessary. If it still doesn't work trip the main breaker for the ac unit off wait 1 minute and turn back on. If it still does not work then you have a more technical proble. Could be a bad thermostat or control board in the ac unit.
Jul 03, 2016 | Audio Players & Recorders
Totaline p374-300 is blank
Have you cleared the float switch?
Aug 03, 2017 | Heating & Cooling
Your drain line is clogged and the float switch is tripped. Locate the piece with 2 wires on the drain. Pull the cup out and look for water. DO NOT LEAVE OUT,you need to shop vac the drain clear.
Jan 30, 2010 | Heating & Cooling
Power went out; now U-Line has no power. Circuit breaker checked; power is plugged in.
1st make sure you dont have 2 dashes in the display. If you do then the board will have to be programmed. If its blank or 0 then unplug the unit for a min. then plug it back in. It should work.
Dec 28, 2009 | U-Line 2115R Echelon Series 15"...
I have a GE Microwave Model JVM1540LM2CS. It started making funny noises like a fan or gear grinding and then it quit working altogether. I have checked the circuit breakers in the house and have...
sounds like the mag fan went out and blew the internal fuse they are ceramic fuses 15 or 20 amp available at hardware stores ,if this blows again it could be the mag overheated,but the thermal breaker should have shut it off before this,thenit can also be your h.v. diode or capacitor shorted
Oct 10, 2009 | Microwave Ovens
The double wall unit (microwave and oven) display went blank
check and see if the oven light is comming on if it comes on is the board if the light donot come on current problem
Apr 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dishwasher stopped working..!!..!! please help
Hi crystal245,
I'm Harvey the Master Plumber.
Your problem is: GE Nautilus Dishwasher suddenly stopped working. NOTHING!! it was fine one day then went kaput the next. I checked the plug in and the circuit breaker but still NOTHING
I run into this often. Ends up being loose, broken or burnt ellectrical connection in d/w junction box most of the time. It's under the d/w behind the kick plate on the right or center. Turn the power off first and remove the wire nuts. Replace wire nuts and/or repair wire ends as nessessary. Beyond that you're looking at a bad control board or failed connection in the unit.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | Dishwashers
WHIRLPOOL QUITE PARTNER ii
there is a thermal fuse attached to the main control, check for continuity if none replace fuse.
Jul 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Jun 23, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
