Question about Yamaha RX-V661 Receiver
Wrong remote I purchased the rx-v661 used but was given the wrong remote I have the rav 352 remote. Can this remote be programed to get into the main menu to change from large front speaker to small so I can use a powered sub. thanks
    Guru:
  • 417 Answers
No but you can change the settings from the front panel of the unit.
Posted on Feb 13, 2014
Testimonial: "Ok. How? I spoke to a Yamaha agent and he said that there was no way to change the setting on the front panel to go to the main menu and change the large front speakers to small front speakers and this is why my sub can only get some of the bass and not the full effect. Help"
  • T-Comtech Repairs
    T-Comtech Repairs Mar 19, 2014
    Switch the unit off, then press & hold the "TONE CONTROL" button & switch it back on. you must make sure you set everything up acording to your speakers ohm\'s, do this in the "SP IMP" rotate the dail to skip through the settings & tap the tone control button to select sub catogorys. if you get stuck giz a shout.
  • T-Comtech Repairs
    better still...........http://www.manualowl.com/m/Yamaha/RX-V66...
No sound from zone 2 speakers on yamaha rx-v661
Have you gone into the speaker configuration menu and turned on zone 2?
Oct 18, 2013 | Yamaha RX-V661 Receiver
Zone 2 vol fix
I'm assuming you mean when you try to turn up the vol on zone 2 it says "zone 2 vol fix" and you want it to be "variable" giving you the control from the remote. Open the GUI menu (Receivers main settings menu) go to (options) select external zone or zone2 then select (Variable) If you have your receiver passing video to your TV it's alot easier to navigate the menu. If you still have problems, post a reply on this thread with your product list including make and model #'s and I can walk you thru the whole process. Hope this helps
Jun 15, 2010 | Yamaha RX-V661 Receiver
I cannot make any changes to my Zone 2 -- cannot change the volume or change the setting from what Zone 1 is on. A blinking symbol that looks like a mushroom appears when you are trying to switch between...
Hi.
Looks like the the unit is locked to region 1.
The Yamaha receiver you listed is region free, therefore I assume you are talking about a different unit, in that case give model please.
If you have the problem with a Yamaha RX-V661, then simply disconnect power cord for ten minutes. And disconnect from power all devices connected to the receiver.
This should reset the system.
Let me know in case it does not work.
Regards.
Nov 17, 2009 | Yamaha RX-V661 Receiver
No volume in Zone 2
Get the original Yamaha remote, go to Set menu, manual setup, speaker setup, and look for "extra speaker." it needs to be set to "zone 2." This is off the top of my head, so it should be pretty accurate. Get used to doing this, though, as this amplifier assignment to zone 2 is prone to resetting itself in those Yamahas.
Sep 05, 2009 | Yamaha RX-V661 Receiver
Zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal power amp.
Setting the RX-V661 remote control to operate Zone 2
1. Using a ballpoint pen or similar object and press the Code set
button. The Transmit indicator on the remote should flash twice.
2. Using the numerical key pad on the remote and key in 9992, the
Transmit indicator should flash.
You will now need to assign the receivers internal amp for Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter button.
5. Arrow to the Sound Menu option and press Enter.
6. In the Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return to the Manual
Setup.
Apr 05, 2009 | Yamaha RX-V661 Receiver
WII
Had the same problem- but had success when I connected the wii to my DVD player, which then HDMIs through the reciever and then HDMI to my projector.
Dec 25, 2008 | Yamaha RX-V661 Receiver
Remote
Hi jimvandy
Most yamaha codes will work some of your unit functions. try 0176 or 1176. These are for a dvr3 comcast remote. You can get the whole list and manual from here
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you still have problems, before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 02, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V661 polarity problem
There is no "fix" the mic is picking up a lack of bass based on room acoustics and is trying to help. There is nothing wrong. If you are using bi-pole or dipole speakers it will always show out of phase.
Feb 27, 2008 | Yamaha RX-V661 Receiver
RX-V661 Receiver
your receiver has zone 2 output which is operated independently of the main reciever. so you can have a dvd playing inthe main reciever and the tuner playing over the intercom. read about it in your manual page 89. in will hook up to 2 RCA jacks in the back Zone 2 out.
Dec 29, 2007 | Yamaha RX-V661 Receiver
Yamaha RX-V800 - No audio on left and right channels
I too am experiencing this problem.... and my receiver is only 5 months old. Its a RX-V661
Oct 30, 2007 | Yamaha RX-V2500 Receiver
Yamaha RX-V661 Receiver Logo
99 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
