Question about Pioneer VSX-92TXH Receiver
My pioneer receiver keeps saying dimmer. how do i get the cbl/sat indicator back on
Synced with a directtv remote but when it gets "un synced" have to use the pioneer remote control. Have to switch the direct tv remote to av2. using the pioneer receiver, I push adv. surround but it will not go back to external speakers, How to I get the cbl/sat to show up on the pioneer receiver when it shows up on the tv screen
5 Suggested Answers
SOURCE: Pioneer Multichannel Receiver VSX-D508 (including cd player & tape deck)
receiver on the screen displaying power off
Posted on Apr 15, 2008
SOURCE: Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Posted on Feb 18, 2009
SOURCE: problem with pioneer vsx-916 av receiver
i have been using this with two speakers and was working perfectly fine . recently i bought two floor standing speakers and worked fine when connected . When i tried connecting all four speakers it showed overload kindly tell me how this could be solved
Posted on May 02, 2009
smarthome2
  • 1114 Answers
SOURCE: Anyone have the remote control code number for the Pioneer VSX515 receiver?
Are you trying to progam another remote to control your Pioneer? If so, check with www.remotecentral.com if it's available, it's there!! Hope this helps
Posted on May 22, 2009
Pioneer VSX-D412 directv remote code
I also have the VSX D412 and DirectTV. My DirectTV remote controls the D412 fine, but I did have the same problem you're experiecing with a Sylvania flat screen that the remote wouldn't operate. I corrected my problem by turning the TV off, then back on using the TV's remote, then telling the DirectTV system that I didn't know the model number and let the system search for the code. Hope this helps.
Feb 17, 2012 | Pioneer VSX-D412 Receiver
Need codes for rcr 460 remote
1. Manually turn on the component
you want the remote to control
(TV, VCR, DVD, satellite receiver
or cable box).
Note: If you press an invalid key
during the Manual Code Search,
the remote does not respond and
the LED indicator light does not
blink. If you do not press a valid
Manual Code Search key (TV,
VCR, DVD, SAT·CBL, ON·OFF,
GO BACK), the search times out
after two minutes. When the
search times out, the LED
indicator light blinks four times
and turns off. The last
programmed code under that
component key is retained.
2. Press and hold the component key
(TV, VCR, DVD, SAT·CBL) you
wish to program. The LED indicator
light turns on and remains on.
3. While holding the component
key down, press and hold the
ON·OFF key. The LED indicator
light turns off.
4. After holding down both keys
for three seconds, the LED
indicator light turns back on.
5. Release both keys. The LED
indicator light remains on.
Throughout the
programming of each key, be sure
to keep the remote pointed at the
IR sensor of the component you
are currently programming the
remote to control.
6. Press and release the ON·OFF key
repeatedly until your component
turns off. Each time you press the
ON·OFF key, the LED indicator
light blinks, and the next code in
the list is sent. This process
continues until all of the codes in
the Code Lists have been searched.
If your component turns off, you
have found the correct code. (If it
cycles through and the LED
and turns off, all codes have been
searched. The Manual Code Search
method is exited.)
Press Stop when TV turns off.
Mar 06, 2010 | RCA Universal Remote Control
Someone sat on the remote control for my Yamaha rx v557 and I have no tv picture--do have sound. System is set up to Direct TV. I can change channels and hear everything fine, but can't get a TV picture It...
If it was the remote that changed the function then likely the mode has been changed. You probably need to have it changed back to the input you plugged your DirectTv into, such as video1 or component, or cable/sat. etc, etc...
Dec 14, 2009 | Yamaha RX-V557 Receiver
Loose sound when changing channels
If your using HDMI. The HDMI technology in version 1.1 & 1.2 was riddled with problems. Check your owners manual for version.Or, try the Coaxial Digital or optical output from your sat receiver to your Yamaha receiver, go into "GUI" "Menu" not sure which on the HTR series and Lock the audio input to Coaxial or Optical on CBL/SAT. Then Test. If it still has issues, check the settings for Audio on the SAT receiver and make sure they are correct. If you still have a problem, use a standard RCA from the sat receiver to the Yamaha. At this point audio should be rock solid on analog. Look on the back of your DSS receiver for the model # & write it down. Then go into the units menu "SAT" and check it's firmware version for version and date. It may need an update. Go to your Sat's website, Directv or Dishnetwork and go to support, enter model # and look for any updates that may apply. Hope this helps
Jun 11, 2009 | Yamaha HTR-6140 Receiver
Need code for Brookstone remote to work W/ Direct TV TIVO receiv
Sense you do not know the make of the receiver I would do a code search. This is how you do it.
Automatic Programming
With automatic programming, the remote control tests all the codes available
on the Code List and assigns the correct code for the selected device.
Although this method can be more time-consuming, it eliminates the need to
look up codes and enter them manually.
1. T urn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. The
remote control is in programming mode.
3. Press and release . The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
4. Press CHANNEL + or CHANNEL - repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• The unit will search for the next code or the previous code if you press
CHANNEL + or CHANNEL - after the device turns on.
6. Press any other button. If the device responds, the remote control has been
programmed. If the device does not respond, repeat steps 2-5.
Good Luck and Please Rate FixYa!
Dec 31, 2008 | Brookstone 538744 Remote Control
I need remote control code number for motorola dvr 6416 III
If this is a remote by UEI or Atlas (usually the black remote that the cable company supplys with the box) the code is 1376.
To set the code, you will need to do the following:
Unlock the Cbl button:
Press CBL once. it will blink once.
Press and hold SETUP until CBL blinks twice. Release setup
Press 982
CBL will blink 4 times, indicating it is unlocked
Program the code in:
Press 1376
CBL will blink twice if the code is accepted.
Re-lock the CBL button:
Press 982
CBL will blink 2 times, indicating it is locked again
If it is not a UEI or Atlas remote, let me know the remote make and model
Dec 01, 2008 | Arris DCT6200 DTV Receiver
Remote code for Pioneer VSX-50 A/V receiver.
Here are the codes for your receiver:
Pioneer 31023, 30014, 30244, 30150, 30630, 30080,
30531, 31384
Here is a link to your manual:
http://www.directtv-advisor.com/support-...
Oct 13, 2007 | One For All URC-3021 Remote Control
Sat/cbl button defaults to channel 17
maybe you programmed it with the wrong code sometimes that happen try the other codes that come with it make sure everything works before you think u got the right one.
Jul 01, 2007 | RCA RCR450 Remote Control
Pioneer VSX-92TXH Receiver Logo
27 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
