Question about GE Dryers
DBXR462GD2WW Wont stop at the end of the cycle
Dryer not stopping
If the dryer wont stop when you open the door, it is the safety switch that is bad...if the dryer just wont stop when it should at the end of the cycle, then it's the main selector switch that is bad..which problem is it?
Jun 09, 2012 | Kenmore Whirpool Maytag Dryer Transformer...
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Wont stop at end of cycle unless u push of button alrady replace timer and motor and motor brd
Hi christian742,
I highly recommend for you to read the Manual which came with the machine.
it should include detailed instructions on how to stop at the end cycle without pushing.
Mar 17, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
The machine completes 2 cycles instead of 1
Based on your description of the problem. The only way this can happen is if the timer is faulty. It is simply skipping the intended end time and continueing the cycle. However when is the timer, it usually wont run correctly for both cycles..but it sounds like you may have sort of lucked out on how it has become faulty. Hope this helps.
Thanks
Nov 22, 2009 | Amana Washing Machines
Washer stopped and wont turn off
Unplug the appliance from power, or trip the circuit breaker and cut power to the appliance for about five minutes.
While appliance is unplugged check that the drain hose is not kinked and empty water from inside the machine.
Let me know if you still have the problem when you connect the appliance back.
If the appliance does not start back, then there is a faulty part, in that case give me the model number as printed on service tag and tell me when the appliance had been purchased, also tell me the country of purchase.
Many thanks.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHING MACHINE DOOR WONT OPEN
Call the manufacture it will be under warranty if it's only 6 months old as the machine will have to be torn down to get to the defective switch, just the top will have to come off if your lucky.
Jun 17, 2009 | Haier Washing Machines
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Wont Stop
probably the timer pcb has gone faulty.
Jan 12, 2008 | Hoover AL120 Front Load Washer
Dryers Logo
11 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
