Question about Car APS921 Remote Starter - Keyless Entry
Where is the valet button - Car APS921 Remote Starter - Keyless Entry
    Problem Solver:
  • 11 Answers
On most audiovox products it's built into the led witch is mounted on windshield if not look for black push button on driver side under dash or the kick panal
Posted on Aug 10, 2014
What is valet
The valet button allows a valet to operate the vehicle without setting off the alarm.
Mar 30, 2014 | Vehicle Parts & Accessories
Tip
How to get a Viper alarm out of valet mode
Exiting Valet Mode with Key Fob:
1. Open the entry door.
2. Press the lock button.
3. Press the unlock button.
4. Press the lock button again.
5. Ensure the red LED is a steady glow.
Exiting Valet Mode with Valet Button:
1. Turn the ignition ON.
2. Turn the ignition OFF.
3. Press and hold the Valet/Program button for 10 seconds.
4. Ensure the red LED is a steady glow.
on Apr 14, 2010 | Vehicle Parts & Accessories
Tip
How to get a Viper alarm into valet mode
Entering Valet Mode with Key Fob:
Entering Valet Mode with Valet Button:
Car starter in valet mode
  1. 1 Insert the key into the ignition.
  2. 2 Turn the ignition switch to "ON." Do not start the engine.
  3. 3 Press and hold the valet/override button within five seconds of turning the ignition on. The valet button is located beneath the steering column.
  4. 4 Release the valet/override button after the security indicator light turns off.
  5. 5 Turn the ignition switch off.
Dec 07, 2013 | Dodge Cars & Trucks
How do you put Prestige APS-200 in valet mode?
Turn on the ignition key than press and hold the valet button until the LED illuminated steady. You are now in valet mode. To turn off valet mode, just press and release the valet button with the ignition on.
Jan 15, 2013 | Vehicle Parts & Accessories
Charged battery on 1997 Toyota Camry now immobilizer will not lock doors and car will not start
Here is the reset procedure:
1. Have the Valet Button in the OUT position. ( It is located on the dash panel left of the steering column)
2. Connect the battery - the alarm will sound.
3. Put the key in the ignition and turn to the ON position,
4. Push the Valet Button to the IN position.
The alarm will be reset, and the Valet Button will glow red.
Move the Valet Button to the OUT position again.
Repeat steps 3 & 4 and the Valet Button will become unlighted.
The car will start and everything will be fine.
Apr 20, 2012 | Toyota Camry Cars & Trucks
Where did they put the valet/program buttom on my 2004 Rendezvous?
This is somebody else's so;ution, but it might give you an idea on where to start. I always thought the valet switch was just a key that you gave to the valet. But inn this case out of my legue, my old dodge pickup doesn't hAVE AND MOST LIKELY NEVER WILL HAVE A VALET SWITCH. So check this so;ution oout and see if it gets you going in the right direction.
There should be a key specifically for a valet.
1) Open one of your vehicle's doors and turn the ignition, using the car key, to the "Run" position. Check to see that the dome light comes on. Make sure that you have the dome light set to the position where it powers the light when the door is opened, as there are usually three settings: one for "On," one for "Off" and one for when a door is opened.
2) Press the valet remote push-button to access the channel that you want to program: once for "Arm/disarm," twice for "Trunk Release" and three times for "Remote Start." The valet push-button is usually located under the driver's side panel, and it must be pressed within 15 seconds of opening the door. The push-button may also be installed underneath the kick panel.
3) Press the valet push button once again and wait to hear a chirping or a honking sound. If you do not hear either of these sounds, your vehicle might have a jumper installed that has turned the valet programming feature off. Refer to your vehicle's instructional manual to learn how to set the valet programming feature to the "On" position. Keep holding the valet button pressed as you continue onto the next step.
4) Push the button on the remote that you wish to assign to a particular valet channel. Press the button on the hand-held valet remote that you wish to assign to a particular valet channel. If you wish to program multiple remotes, repeat this step for each of them. If you program four or more remotes, the old programming will be erased.
5) Let go of the valet push-button and exit your vehicle. Your handheld remote is now ready to use.
Tips & Warnings- Some valet remote channels require different programming individually, so refer to the owner's manual or to the link provided in the "Resources" section of this article, for specific instructions.
- Valet remote programming methods may vary, depending on the vehicle's make and model.
  • By avatar11.jpgBraunson Y309 days ago
    Braunson Y Level 2
    • 467 Solutions
    • 282 Score
Dec 19, 2011 | Viper Security and Remote Start System...
What dose the valet button do and where is it situatedin the car
The valet button is to the right of the steering column and is quite a large button and has the words 'VALET' clearly written on it. I think it allows you to lock valuables in the glove box but allow a Valet or Service engineer to drive the car - they will not be able to get into the glove box. I sdon't have the XK8 owner's handbook, and so I am guessing about the function of the Valet button, but that is what a similar device does on my Merc.
Aug 25, 2011 | 1999 Jaguar XK8
Where is the valet switch on a 2004 chevy malibu LS?
Tips & Warnings - Some valet remote channels require different programming individually, so refer to the owner's manual or to the link provided in the "Resources" section of this article, for specific instructions.
Feb 17, 2011 | Keyless Entry Remote Fob Clicker for 2004 ...
How do program a new 488v led remote for my car?
Open the drivers door, press and release the valet button one time, press and hold the valet button, siren will chirp. While holding the the valet button, press and release the the lock button on the remote. siren should respond with a long chirp. Release valet button, trun off ignition, test remote.
Sep 15, 2010 | 488V LED 2Way Remote
Car APS921 Remote Starter - Keyless Entry Logo
47 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
