Question about Proform 6.0 CE Rear Drive Elliptical Trainer
Sound coming when pedalling - Proform 6.0 CE Rear Drive Elliptical Trainer
Why is clutch pedal making a single clicking noise everytime it is released ?
The click you are hearing is most likely coming from the clutch safety switch, which prevents the car from starting unless the clutch is fully depressed. Some vehicles use a relay to activate/deactivate the safety feature when the clutch pedal is cycled.
Dec 24, 2014 | 2007 Hyundai Elantra 2.0
2003 Saturn Ion 2 Clutch Pedal
PEDAL RETURN STOP ADJUSTER BROKEN ON PEDAL BRACKET
Jan 12, 2014 | Saturn Ion Cars & Trucks
My g1x zoom pedal turns on but no sound will come out ? HELLLP ASAP.
did you check the instrument cables? could be one or more of them is shorting
Oct 19, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
2001 ford escape makes a hissing and high pitched squealing sound when the brake pedal is released?
You need to have the brakes inspected. This noise is the brake pad wear warning tab hitting the brake rotor.;
Jun 27, 2012 | Cars & Trucks
Air pressure sound when i push on the brakes
air pressure sound may come from a leaky vacuum hose or bad check valve at the booster or master cylinder.
But, I think that it's normal to hear a soft hissing sound when depressing the brake pedal which comes from hydraulic fluid going through the passage ways.
Is the pedal hard?
Sep 30, 2010 | 1997 Chevrolet Suburban
Replaced rear brake pads, now there is a hissing sound coming from brake pedal when i start it , come to complete stop and after i turn car off .what is the hissing or air pressure release sound coming...
There are 2 things that can use vacuum near the brake pedal. If you have cruise control, there is a safety switch on the pedal to shut off the curise when you apply the brake. This switch may be leaking.
The other part is the brake booster, which is actually in the engine compartment but bolts to the firewall, and your brake pedal mechanism pushes into the booster. You will need to get your head under the dash with the engine running and press on the pedal to locate the leak--on the switch or on the wall.
Sep 07, 2010 | 2004 Ford Expedition
Clicking sound when pedal
Dry or bad bearings in either the right pedal or the bottom bracket (shaft between the pedals).
See this article, particularly the paragraph, "Symptoms of a bottom bracket needing overhaul"...
http://en.wikibooks.org/wiki/Bicycles/Maintenance_and_Repair/Bottom_Brackets/Bottom_bracket_overhaul
Jul 17, 2010 | Pacific International Mongoose 26" Men's...
Problem with the sound? Or is it?
I have this exact pedal. The sound should change as soon as you start pressing it down. With a wah, the frequencies are low at the heel down position and steadily change to a treble higher sound when in the toe-down position. Does the LED on the right side of the pedal come on when you press down? Are you using a fresh battery or a power supply with enough current? Is the "loudness" knob effecting the tone when turned up? If the answer to all of these questions is yes...then I would return it for a new one or send it to Morley for repair. They are nice sounding pedals. The problem could ultimately lie in the optical sensor that controls the wah effect.
Jul 29, 2009 | Morley George Lynch Dragon Wah Guitar...
Metal Pedal mutes my guitar.
Sell the pedal and get a digitech, or convert it into a looper pedal.
Apr 05, 2009 | Boss Mt 2 Metal Zone Effects Pedal
GAS PEDAL
Check all the vacuum lines,sounds like one of them has split, or come off. Have somebody press the pedal while your listening under the hood to see if you can find where the air is coming from.
Just press the pedal enough to hear the air.
Jan 28, 2009 | 2001 Ford Taurus
Proform 6.0 CE Rear Drive Elliptical Trainer Logo
23 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
