Question about McCulloch Garden
Trigger start/stop switch broke - McCulloch Garden
    Top Expert:
  • McCulloch Master
  • 2,931 Answers
You'll need to get that replaced.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
trigger start/stop switch broke - helpful-rwwceix4simen0bu2pand4lt-2-0.png
Posted on Feb 22, 2018
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
I switch the pressure washer on motor starts pressure builds up motor stops. OK pull the trigger on the lance the moter starts sounds different water pressure low. Release trigger motor still runs.
It isnt very clear your explanation of the problem but what type washer do you have first? It sounds like you have a bad unloader or need a new variable nozzle tip. Can you explain in more clear detail. Thanks
Feb 16, 2015 | Garden
Front Wipers - not working
If you can move the wiper blades by hand, you probably broke-stripped the gear in the wiper motor.
Dec 18, 2012 | 2002 Chevrolet Venture Passanger
How do you reset the fuel pump shutoff switch 1995
If the Engine Cranks but Does Not Start or Does Not Start After a Collision Fuel Pump Shut-off Switch if the engine cranks but does not start or does not start after a collision, the fuel pump shut-off switch may have been triggered. The shut-off switch is a device intended to stop the fuel pump when your vehicle has been involved in a substantial jolt.
Once the shut-off switch is triggered, you must reset the switch by hand before you can start your vehicle. The switch is on the left side of the trunk...
This and other details can find in Mercury-Cougar-Owners-Manual
Hope helps.
Jul 13, 2010 | 1995 Mercury Cougar
Safety trigger will not push down to pull trigger
Up inside the trigger is where the safety hits, it moves in the way of the trigger to get it to fire, but it has to hit something in between, i have the same gun, only older, and I deactivated the safety so I could get in tight spots. You should be able to see what is stopping it from moving, then see if the part is bent, broke, missing, whatever. I don't recommend disabling it. But you want to get it going. Hope this helps.
Apr 02, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
My dyson dc 16 hand held vacume stops & starts while in use, each time you pull the trigger it will start again but then stops after a short while untill i pull the trigger again.
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
Apr 01, 2010 | Vacuums
Solar welder 2175 wire keeps feeding wont stop doesnot arc until trigger is pulled
Look on the front pannel. thier should be a "latching Switch" indicated by "4 X 2" little arrowes. The 4 is " pull the triger -- the release the arc continues, the "2" is pull the trigger and the arc startes release the trigger the arc stops simplesssssssss
Ken
Dec 14, 2009 | Welding Tools
I have a Ryobi RE175. It just stopped working
1. Shut the power off, and disconnect your Ryobi
router. It could be the start/stop switch. So, you
can begin checking the switch contacts using the
multi-tester. Set if at 1 x 10 Ohms. Put the probes
of the tester across the switch terminals. Pressing
the trigger on will move the tester indicator to zero
if your switch is okey. Otherwise, no moverment -
the trigger switch need replacement.
2. Should the trigger switch proved to be okey, Check
the carbon brush of the unit, short carbon brush??
you have to replace it.
Nov 03, 2009 | Electrical Supplies
When hammer drilling after drilling a few holes it stops then starts then stops then starts etc.#5370-1 magnum .i don't believe it is the cord
check the trigger switch inside the gun , a few small screws in the casing will have to be unscrewed then take the gun in half and check the trigger switch connections and possibly replace the switch I have had this problem before with no obvious signs of wear or un connected connections but then i replaced the trigger switch and it worked fine
Aug 21, 2009 | Milwaukee Drills
Garden Logo
15 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
