Question about Sharp Televison & Video
Sound cuts out on sharp tv
Sound mutes after a few minutes
4 Suggested Answers
SOURCE: Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Posted on Nov 10, 2008
  • 636 Answers
SOURCE: My 37
Your lucky you got that out of it, this is a common problem with this unit, the solder that is used on the sound card doesn't like heat and melts. You can take the sound card out and clean with alcohol for a temp fix, but this is only a temp fix. Sound card cost approx. 340 bucks my fix was a sound surround system. sucks hey!
Posted on Aug 11, 2009
Testimonial: "Thank you very much Mike. I was leaning towards the sound card and you confirmed that along with additional information that was very helpful. "
SD Tech
  • 14553 Answers
SOURCE: muted my sharp le 810 and now i can't retrieve the sound
If you push the volume button on set does it show on screen?
My guess would be the sound may be turned down on the box or tv or maybe in the TV menu the speakers may be turned off.
Does not sound (pardon the pun) like a circuit repair but like an error.
Check all audio settings or options first in the set and then the box.
Posted on Mar 22, 2012
SHARP TV 25L-M100B HAS NO SOUND
Is the "mute" button on?
If so, try pressing the mute button again.
-Steve
Mar 11, 2015 | Sharp Televison & Video
I have a sharp aquos tv model lc32d6u, we have lost the audio, we have tryed turning the set on and off, nothing. we are serviced by Comcast and it is not the box. I can hear a small click when we turn the...
Try this
1. Power off both the TV and the DVR.
2. Plug in the HDMI cable to both units.
3. With the DVR off, press and hold the power button on the unit until the word BOOT appears on the display.
4. Wait until the unit reboots and shows the clock again, then power the TV and the DVR up.
5. Choose the appropriate input on the TV for HDMI.
6. Use the SETTINGS button on the DVR remote to get into the "more settings" option.
7. Find audio settings and choose HDMI output, press select.
Hope that helps.........
Jun 28, 2008 | Sharp Audio Players & Recorders
Volume Stopping Instantly
A few things to consider: if mute on the set is not on what about the box if you are using one?
Speakers could be switched off in the set.
There could be a internal / external speaker switch(not common but possible)
Sound on the set could be muted or turned real low or off.
if the image you see on the screen is there--either it is from the set or a box if one is used.
only a few things other than the sound circuit being bad will cause this--very few sets with actual no sound problems are around.
Apr 03, 2012 | Mitsubishi Televison & Video
Muted my sharp le 810 and now i can't retrieve the sound
Mar 21, 2012 | Sharp Televison & Video
LG LCD TV/DVD - I have full picture and sound with
is a mute function enable or a defective control board. Needs to be checked. send to repair store.
Jan 16, 2010 | LG 42LB1DRA 42 in. LCD Television
After 4 years of great service my tv cuts of by itself. I unplug for a few minutes and plug it back in and it plays for 30 minutes and cuts off again
Your power supply is going. It is probably a capacitor that has dried out or some other overheating problem.
Tim
Nov 26, 2009 | Sharp 25N-M100 25" TV
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
No sound
Please try unplugging the TV for two minutes then replugging and turning it back on. Werked fir me!
Dec 12, 2008 | Sharp Aquos LC-32D40U Television
Problem with my Aquos lc32d40u
Your inverter/lamps are bad. Those are only available with the LCD panel as an Assembly, and that is worth more than the TV.
Mar 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
15 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
