Question about Whirlpool WTW4800XQ Washer
Reset control panel
Does anyone know sequence to reset circuit board
It wont start. the hi temp and heavy button are the only buttons that come on
OK I am not an expert but I have spent the last two weeks learning about and fixing my dishwasher! Hopefully I can save you a headache. Try the following:
* Flip the switch off and on in your breaker/circuit box. May reset your washer.
* If that doesn't work, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If normal function still does not resume, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit/toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
Hopefully some of that helps!
Jul 08, 2012 | Maytag 24 in. MDBH950AWS Built-in...
Washer will not start
There may be some additional instructions specific to your model hidden in an envelope behind the kickplate of your washer.
Jul 03, 2012 | Maytag Dishwasher
Wont turn on is thier a reset button
* Try turning off the switch for a longer period of time - 10-15 minutes. This may reset your washer.
* If any of your button lights come on but a regular cycle will not start, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If your buttons do not light up or normal function still does not resume after the reset, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit/toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is power getting into the machine and that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to the possibility of a control (button) panel issue and you may try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
Jul 02, 2012 | Maytag Dishwasher
Dishwasher control panel unresponsive
* Flip the switch off and on in your breaker/circuit box for 10-15 minutes. May reset your washer.
* If normal function still does not resume after that, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit or toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If everything looks good but that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
Apr 18, 2012 | Maytag MDB7609AWS Builtin Dishwasher
My Kitchen Aid dishwasher, model KUDK03FTSS3, is stuck in a loop of some sort. It starts, but freezes after a few minutes. Does anyone know the reset key sequence to make this go away? Kitchen Aid customer...
Hi. Pressing and holding the cancel button may reset the unit at this time,as well as, pulling the ac plug out of the wall outlet for five minutes. With that said, I will provide the proper reset sequence below. 1. Open the door of the unit slightly. 2. Within three seconds, press the following sequence in this order-high temp scrub,energy saver dry,high temp scrub,energy saver dry. 3. After the sequence, close the unit door and latch it. 4. After the door is closed, press the cancel button. This will reset the main control, unless there is major damage to the circuitry of the control board.
Oct 13, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a frigidaire fdb520rhs2a that will not come on I checked the circuit breaker and it's on. I ran the hot water for 10mins and still nothing.
Remove the bottom access panel in the front of the dishwasher. In a plastic envelote there is a technician diagnostic sheet. Read where it says start auto diagnostic mode. There are like 6-10 buttons you have to hit in a sequence. The sheet will also give you what is wrong and what to replace/ reset. If you cant enter diag mode than disconnect power remove the door panel and access the console. Open the control board and see if there is a 20amp fuse near the control board test this. This fuse is designed to protect the control board. If bad replace. If you have any more questions please comment me back.
Jul 30, 2011 | Frigidaire Dishwashers
My GU2475XTVY0 built-in dishwasher has the "Normal" light flushing since yesterday morning. We pressed "Cancel" button, other buttons, and finally turned the power off and on, but it didn't do anything. Do...
Hello- The touch control pad is failing and must be replaced. If unit is under warranty, get it serviced. This control is about 125$. Let me know if this info helps. Thanks-Ed
Mar 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
HP 4250 laserjet will not go through the start up sequence.
Well first do what joe said about checking the Plug on the Display, <Here's another solution did you also check the cables( Power Cables going to the format bd ? Sometimes you can bent those pins easily, I have seen it and ok I done it once on HP 4 plus when i first started out as a tech ? Check that ? May I asked What was the reason for replacing the Formatter board in the first Place ? were you getting an error ?
Mar 19, 2009 | HP LaserJet 4250n Printer
Notevision
I found that the locking code is memorized by components on the dvi-circuit board. Alas, I can't tell you how to reset the code.
Regards,
John
Sep 28, 2007 | Sharp Notevision PG-M20X Multimedia...
Whirlpool WTW4800XQ Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
