Whirlpool sm8525492 how do I take the back off
3 Suggested Answers
cjrepairs
  • 60 Answers
SOURCE: My whirlpool washer, model #sm8525492-a doesn't
check that there is a rise on the outlet pipe as if this drops onto a low level it may cause the problem you describe.
Posted on Aug 16, 2009
  • 2468 Answers
SOURCE: my whirlpool washer sm8525492 will
your lid safety switch is bad,remove the control panel,set it back,then remove 2 brass colored spring clips from top cover behind the lid,tilt entire cabinet toward you and remove,lid switch can now be replaced from under the cabinet that you removed
Posted on Dec 22, 2010
Forgot how to put whirlpool washer back together
Go to www.repairclinic.com and enter model. You will be presented with a list of common replacement parts and may be able to view a generic Whirlpool disassembly video. Following the disassembly procedure in reverse should get your machine back together again.
Feb 25, 2017 | Whirlpool Washing Machines
How do I get water flow back after replacing a Whirlpool water filter?
The replacement filter may have been installed backwards with the flow direction arrow point toward the source.
May 11, 2014 | Whirlpool Refrigerator Water Filter
Where is the reset button on a Whirlpool LER7620LWO?
No, there is no reset button on any whirlpool dryer designs, but if you unplug the machine for a few minutes then plug it back it in that should reset the machine back to factory settings.
Jun 21, 2012 | Whirlpool Dryers
I need a manual for a Whirlpool Dryer.
Hello & Welcome to FixYa
Please get back with the model# of your dryer for the manual and please tell me what type of manual you need.
Kevin
Jun 26, 2011 | Whirlpool Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    My whirlpool washer sm8525492 will not spin or agitate
    Dec 22, 2010 | Washing Machines
    Cannot get the casing back on a whirlpool ultimate care ii washer
    You need to set it on the clips in the front at an angle then tip the casing back into position. Here is a video that will walk you thru
    Disassembling a whirlpool style washer
    Oct 23, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
    My whirlpool washer, model #sm8525492-a doesn't seem to be holding water. It isn't leaking water on the floor.
    Make sure the drain hose outlet is higher than the water level in the tub or the water will siphon out on it's own.
    Aug 16, 2009 | Washing Machines
    Whirlpool lsr7233eq0. The machine is level but
    Grab back of washer on both sides and tip towards you and drop gently back. This will level the back legs which are self adjusting. Sometimes they stick You may have to pry with a screwdriver down towards floor to free them if this is the case.
    Jul 07, 2009 | Whirlpool Washing Machines
    Washing Machines Logo
    23 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
