Question about Stanley 5 Watt Led Waterproof Rechargeable Spotlight Camping Hiking Flashlight
Fatmax lionhals 12v dc 500mA DROdropped Iin waterand wont light. is there a wayto repair?
Is the battery replaceable
Stanley Fatmax 450 Amp (Model J45TK)compressor starts and then stops right away. The charge is full showing the green LED light on.
You will likely have to open up the case to look inside.
The main components will be a circuit board, a 12v power supply, a 12v air pump and a 12v rechargeable battery. It sounds like a loose connection on the air compressor pump. When you turn it on it normally vibrates and is loud. This may be enough to shake loose a wire connection. If so it should be an easy fix to crimp or solder.
Aug 29, 2017 | Stanley Vehicle Parts & Accessories
Interior wall panel battery lights does not lightup when 120 power is not pluged
The lights run off of 12V DC and use your RV's batteries to run when not plugged in. When plugged in it uses the AC and converts it to DC and runs the lights.
Please check your battery disconnect switch. It's most likely off. In my Winne there is a battery disconnect switch which disconnects the two batteries near the door. Lights wont work when unplugged and the switch is off. Lights works when plugged in or unplugged and switched on.
May 05, 2015 | Winnebago 2015 Ultralite 27RBDS
How do I charge the Fatmax 450 Amp by Stanley
It should come with a DC or AC charging plug. All you have to do is plug it into either the 12v socket on your car, or your AC wall outlet, depending on which plug(s) you have.
Feb 11, 2014 | Vehicle Parts & Accessories
Linksys wrt54g manual
Power specification depends on the Hardware version
WRT54G 5V 2A
WRT54G V1.1 12V 1A
WRT54G V2 12V 1A
WRT54G V2.2 12V 1A
WRT54G V3 12V 1A
WRT54G V3.1 12V 1A
WRT54G V4 12V 1A
WRT54G V5 12V 0.5A
WRT54G V6 12V 0.5A
Nov 28, 2013 | Computers & Internet
Cannot find the charger for my vectorlite 1.5
Hi sast.
I found this on amazon: HQRP AC Adapter Charger for Black Decker VEC119SH TYPE 1 VEC120 TYPE 1... It says that fits, but anyway contact the seller and ask.
Hope this was helpful.
enjoy
Feb 28, 2011 | Vector 1 Million Rechargeable Spotlight
I lost the adapter/charger and purchased a new one of the same size. The light will work when plugged into the car cig lighter, but not while plugged into the dc adapter (has been plugged in for approx. 3...
The battery life for these lights are for about 2 years at the most if left uncharged. The best way to determine if you need new a new battery or batteries would be to dismantle the light, remove the batteries and check the voltage with a volt meter. If they are dead, you may be able to fine a suitable replacement at: http://www.batterymart.com/c-04-12-volt-sealed-lead-acid-batteries.html
Nov 12, 2010 | Vector 20 Million Power Series Spotlight
Fuel pump will not run in car but will on the
You need to cuss a whole lot more than twice. A voltage meter would be more useful in determining the actual voltage making it to the fuel pump. Something around 12v DC would be appropriate. If you are not getting at least 12v, you need to check the battery, the starter relay, and the fuses to the fuel pump for any corrosion, and make sure you are getting at or near 12v DC.
Feb 14, 2010 | Daewoo Lanos Cars & Trucks
I have a Duralast Jump Starter BP-ELG and the power cord got thown away I need to know the voltage, the current and the polartity.
Since you say, it is a 12v DC portable Jump starter, the battery inside it is also a 12V battery. You need a 12V charger (eliminator, wall adaptor or whatever you may call it) Regarding current, it could be anything above 500 mA. Better if it is a 1A or 2A or even 3 A depending on the amount you are willing to spend. Now is the most important part. The polarity. I do not know it since i do not have this equipment. Most chances are that you will find (on the RoadPro) a circle and a dot (along with a +VE and -VE marked near it) around where you plug in the adaptor. For most equipments the outer circle is the -ve and the inner dot is the +ve. (unfortunately this could be reversed in some equipments) If you can find this notation on your RoadPro you are lucky. Just go to any electronic shop and buy an adaptor (12V) that matches this circle and dot notation. The same symbol representing polarity will be marked on the adaptor also. Else, you will need the assistance of someone who can check the continuity using a multimeter. This way you can find the polarity. It is pretty easy. Hope this helps.
Jan 11, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Stanley 5 Watt Led Waterproof Rechargeable Spotlight Camping Hiking Flashlight Logo
43 people viewed this question
Top Stanley Camping, Backpacking & Hiking Experts
Richard Lilja
Richard Lilja
Dave Reilly
Level 1 Expert
oldhess
Level 1 Expert
Are you a Stanley Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
