Question about Hampton Bay Dryers
WIRING DIAGRAM FOR 2 SPEED AIR CONDITIONING FAN, WIRE COLORS ARE BLUE,RED,ORANGE,YELLOW
  • 52 Answers
SOURCE: hampton bay ceiling fan
This should do the trick. Good luck and make sure the power is off.
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
Posted on Jan 29, 2008
Crossedwires
  • 44 Answers
SOURCE: how to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Posted on Feb 09, 2008
mikedurland
  • 481 Answers
SOURCE: I have to change the
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Posted on Jul 02, 2008
we have a hampton bay fan burning smell coming in didnot run
Posted on Jul 07, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
My old thermostat has 8 wires, red, white, green, gray, black, orange, blue and yellow. I have the 44110 model need help connecting the wires
open unit and see what wires are running what never trust the colors.white heat'yellow cool'red 24v,green fan,blue prob your com,
Apr 17, 2012 | Heating & Cooling
Need help wiring this theromostat. I ahve the following color wires.....Green Red Black Blue White Yellow and Orange. Need to match them to the following connections: G RC RH Y/O W/B Y1
G= Green Wire (Fan) RC= Red Wire (Power Cooling) Y1= Yellow Wire (Cooling Contactor) RH= Black Wire (Power Heating) WB= White Wire (Heating Control) YO= Orange Wire (Damper Control)
Blue Wire is usually to C= Common
Nov 28, 2010 | Heating & Cooling
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
THE WIRING ON THE FAN CLUTCH GOT CUT AND THE WIRES FROM THE TRUCK ARE YL/RD,BLK/RD,GREEN/GRAY,RD/GREY,GREEN THE WIRES FROM THE CLUTCH ARE RD,GREEN,WHITE,ORANGE,BLACK. TRYING TO BE SURE BEFORE I CONNECT...
1) ECM Fan Clutch 1) K160 18BR/OR Park Lockout Solenoid Control Green
1) BR / OR = Brown/Orange unit with Green
2) K900 18DB/DG Sensor Ground 2) Black
2) DB / DG = Dark Blue/Grak Green unit with Black
3) K161 18BR/LB Fan Speed Sensor White
3) BR / LB = Brown/Light Blue unit with White
4) Not Used
4) Not Used
5) F856 18YL/PK 5 Volt Supply Orange
5) YL/PK = Yellow/Pink unit with Orange
6) F504 20GY/PK Fused Ig. Sw. Output Red
6) GY/PK = Gray/Pink unit with Red
With this, you have 5 due color cables unit to the 5 full color cables. Run.
Good luck, and rated this help (and us chat).
Aug 27, 2009 | 2004 Dodge Ram 3500 Truck
Wiring diagram for 1999 dodge durango
1999 DODGE DURANGO
4DR SUV
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery RED/BLUE (+) RADIO HARNESS
Accesory RED/WHITE (+) RADIO HARNESS
Ground N/A
Illumination BLACK/YELLOW (+) RADIO HARNESS
Dimmer ORANGE (+) RADIO HARNESS
Amp Turn On DARK GREEN/RED (+) RADIO HARNESS
LF Speaker (+) DARK GREEN
LF Speaker (-) BROWN/RED
RF Speaker (+) BROWN/YELLOW
RF Speaker (-) BROWN/LIGHT BLUE
LR Speaker (+) WHITE
LR Speaker (-) DARK BLUE/RED
RR Speaker (+) BROWN/WHITE
RR Speaker (-) BROWN/ORANGE
Amp Location PASS KICK PANEL
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
May 10, 2009 | Audio Players & Recorders
1996 eagle vision radio wiring
1996 Eagle Vision Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Light Blue
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Pink
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 3 1/2′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 23, 2009 | 1996 Eagle Talon
I need color codes
Constant 12V+ Black/Yellow
Switched 12V+ Red/White
Ground Black/Light Blue
Illumination Orange
Dimmer Pink
Antenna Trigger Orange/Red
Antenna Right Rear
Front Speakers 4" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Feb 19, 2009 | 1996 Dodge Intrepid
Dryers Logo
13 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
