Need to replace switch
SOURCE: Bunn GRX-B leaking from bottom
If you will locate the date code on the bottom of the brewer and contact Customer Service, the machine can either be replaced or repaired at not cost or if over 3 years old, at a reduced price.
SOURCE: Need wiring diagram for Bunn BX or GRX coffee
I do apologize but these diagrams are not available. What is the problem with the machine? If you will get the model and code date from the bottom of the brewer and contact customer service, we can help resolve your issue. The machine carries a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, then it will be replaced at a reduced price.
SOURCE: I need a wiring diagram for a Bunn BX coffee maker
SOURCE: Vacation Switch
The vacation switch should be in the "I" position and the "O" should be in the up position and you will see orange around the switch. If this does not correct the issue, then please call 800-352-2866 for further assistance.
Testimonial: "Thank you, it was helpful."
