Question about Haier ESD210 / ESD211 Built-in Dishwasher
Haier dishwasher reset
All the lights are flashing and won't run. I have uplugged and tried to reset but no luck.
3 Suggested Answers
ehmbee
  • 9 Answers
SOURCE: Haier Dishwasher hdp18pa - Power reset
Are you blowing a fuse or throwing a breaker? Either way there is a chance that no outlet you have chosen to test with yet is on a circuit with sufficient amperage-I had this with a microwave I recently had installed. If you have the manual, check for requirements regarding amperage. You then need to be sure you are using an outlet with amperage comparable to the requirements-this is on your fuse or breaker. If your requirement is, say, 20 amps, a 15-amp or less breaker or fuse is going to fail. I had to go to a 'clean' circuit from my garage with nothing on it to find out I did not have enough amps in my circuit. My solution was a dedicated breaker. Another option is to use my second option (which I did not need), to plug it into a gas generator with sufficient wattage/amperage. This ensures nothing else is on the circuit.
Failing all that, it could be the power supply for the washer, a circuit board issue, etc. Don't mess around if you don't understand electricity, though-it's not worth frying yourself.
Finally, if it worked ok before and this has just begun to happen, I'd tend to think it's an issue with the washer itself. Hope this helps.
Posted on Jul 07, 2009
  • 17 Answers
SOURCE: Haier dishwasher wont run and shows a code OP
The code "OP" means the door is open. I would suspect you have a faulty latch. The dishwasher thinks the door is open and will not start the cycle.
Posted on Aug 02, 2009
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
DRIVE BELT LIGHT FLASHING ENGINE WONT REV UP
Yes, it is called replacement of the drive belt. The reason it won't accelerate is because the belt is slipping.
Feb 12, 2012 | Motorcycles
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
KUDS01FLWH6 clean light flashing, replaced fuse kit and wire harness but still won't run after reset
Hi David, welcome to FixYa for starters.
Sorry to hear about your difficulty in finding a remedy for your dishwasher problem, but I believe I have a fairly simple solution to a very common problem, specifically with these machines (provided the model number is indeed KUDS01FLWH6 as indicated).
I'll direct you to my blog site as opposed to writing the complete solution out here,
http://fixedappliance.blogspot.com/2011/10/problem-with-whirlpool-mdbh969aws.html
if you cannot link up to it for any reason, please let me know. good luck and thank you for choosing FixYa.
Regards,
Macmarkus :)
Nov 07, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
I have a haier dishwasher but the water wont drain out of it. the power light remains on but turning the settings dial has no effect - looks like the pump may be blocked. how can i carry out a factory...
you maybe right but before doing machine reset button, you need to clean the machine be sure there's no jam in mechanical parts. also not all machine have reset button outside, some are hide and inside the power supply module so look for it and be careful.
Feb 04, 2011 | Haier HDP18PA Stainless Steel...
Where is the reset button on my TH-42PX75U high definition plasma television?
typicaly there is no actual reset button try uplugging for 2-3 hours it might work for you as its how a hard reset is done if not it may be a factory or brand specific method to do so on your tv but usually the hard reset is sufficient ok good luck :)
Jan 13, 2011 | Panasonic TH-42PX75U 42 in. Plasma HDTV
Haier ESD210 / ESD211 Built-in Dishwasher Logo
35 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
