Question about Proform Exercise & Fitness
Moved the treadmill and now it is making a very loud vibrating noise when it is turned on. Can't tell where the noise is coming from.
  • 64 Answers
SOURCE: While running on the treadmill there is loud noise
Probablt don't need a new belt. You need to isolate noise. Listen and look for any signs of rubbing in the area that noise is comming from.
Posted on Jul 27, 2009
  • 103 Answers
SOURCE: Proform 400GI Treadmill making a very loud noise,
This definitely sounds like the drive motor. One way to check is to remove the drive belt and run the motor without the walk belt connected. Obviously if you still have the noise it will be a motor issue. If not then it will be one of the 2 rollers. Good Luck! Tim
Posted on Nov 13, 2009
maxtreadmill
  • 832 Answers
SOURCE: The back roler is making a very loud vibrating
Best way to check the roller to see if the bearings have failed is using a long shafted flat tip screw driver and place it on the end on the adjusting bolt. Then put your ear on the handle and listen, if the sound has amplified then the roller is defective and needs replacing. If not then check the front roller the same way because sound travels thru the frame and the problem maybe originating their. Call Icon Fitness to order part their is 1-800-999-3756.
Posted on May 05, 2010
Testimonial: "thank you very much. I took it to pieces and fixed myself"
maxtreadmill
  • 832 Answers
SOURCE: Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Posted on Jun 11, 2010
roadtech7
  • 297 Answers
SOURCE: Turn on treadmill, and hit
Hello, How long has this been doing this? Did you just get it? Have you replaced any parts on it?
Matt
Posted on Jan 25, 2011
What causes our front loading washer to make exceeding loud noise when it enters a spin?
Sounds like a bearing seal is going. The seal has ruptured and grease of seeping out. The loud noise is the bearings rubbing against each other without adequate grease to reduce the friction. Failure will come soon if it is not fixed. The vibration is coming from the friction and possibly damaged ball bearings .
Mar 11, 2015 | Washing Machines
Nordictrack 1900c treadmill making a horrible loud screeching noise when turned on
Sounds like your belt is slipping. Check your manual, it'll probably tell you how to service it.
Jan 25, 2015 | Nordic Track Exercise & Fitness
We moved the bed and now the lights dont come on and it makes a loud noise .
Having the same exact problem! Any luck fixing it? If so please send help my way!
Apr 10, 2014 | Wolff Sunvision Pro 24S Tanning Bed
2003 Mitsubishi Outlander Grating Noise, Front Struts?
It very well could be the strut.
smaller chance could be the CV axle.
Also have the splash guards/heat shields checked to make sure they are all tight in place.
Mar 18, 2014 | 2003 Mitsubishi Outlander
Have proform xt 70. It makes a loud noise when turned on, less noise when walking.
see the video and do it inmediately+ roller bearing Too. God bless you
Jan 07, 2013 | Proform XT 70 Treadmill
My unit outside is working fine but it is making a lot of noise. All my neighbors are telling me that this is not normal. What can I do to reduce the noise. It is spinning fine but it makes loud noise.
Is the condenser coils clean..... If not take a hose and wash the condenser coils But make sure you shut the Main power off to it. Has the unit been charged with Freon lately??? If so they may have gotten it overcharged which will cause High head pressure and make the compressor noisy..... Or is it out of level and not setting on a stable surface. causing a vibration noise. You can put rubber pads under the AC if it is a vibration noise...... Also the Compressor may be going out..... It is hard to tell with out hearing it first hand....Hope this helps If you can't get it to quite down I would setup a Service Call to have them Service the AC and that you are having a loud noise coming from the unit....
May 05, 2011 | Goodman CLT48AER48 Air Conditioner
Jun 10, 2010 | Horizon AFG 5.0 AT Treadmill
It started making a loud noise and when I turn it on and step on it it doesn't even run...what can I do?
Hi, did you fix you treadmill's loud noise?
I have a 530X Proform and I'm having the same problem with my.
May 21, 2010 | Exercise & Fitness
Proform 400GI Treadmill making a very loud noise, which is worse when using speeds between 2.7 and 3.1, noise is so loud can't hear tv when turned up to full volume. It makes the noise without anyone...
Nov 04, 2009 | Proform 490GS Treadmill Walking Belt
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
Exercise & Fitness Logo
18 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
