This cluster bears a single brand, It always has the upper hand; It's made of leaders of one tribe, Black or red, they number five
Can this riddle be answer
2 Suggested Answers
  • 127 Answers
SOURCE: Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Posted on Jan 06, 2010
How many members in gram panchayat?
Gram Panchayat is the association of chose panchas by the individuals from Gram Sabha of the town. It is a self-government association. The quantity of individuals in a Gram Panchayat relies on the number of inhabitants in the town.
For the most part, the quantity of chose panchas in a Gram Panchayat changes somewhere around seven and seventeen individuals. Be that as it may, it might differ from state to state. There is procurement for reservation of Scheduled Castes, Scheduled Tribes and Women competitors. The leader of the Panchayat is known as "Sarpanch".
Ajay Chandrakar
Mar 29, 2016 | Office Equipment & Supplies
Sim network unclick pin
You can get the Sim Network unlock pin for your Alcatel OT-800 one touch Tribe phone from WickedUnlock.com here you need to specify your country,Network name to which it is locked,IMEI number of your phone.Then they unlock pin to you through mail with unlocking instructions.Using this you can unlock your phone from Network lock easily.
Nov 30, 2013 | Alcatel One Touch Tribe Ot-800a Black...
Wiring 15312 timer
You are asking about GE 15312 timer.
Open following link for exact single-pole wiring illustrations:
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
May 30, 2012 | GE Hardware & Accessories
I would like to replace five Intermatic wall switch timers (model WG230-6) that are not presently working.
The Intermatic E1020C timer is a 120 volt, single gang, single pole switch. This means it must ONLY be used on 120 volt circuits (to operate the internal timer motor), will fit into a standard electrical swithbox (does not require over or double sized boxes) and will replace a standard, single pole switch ie: has ONLY two terminal screws (not including the green ground terminal) and if a toggle type - has ON and OFF on the handle. The only additional requirement is that the switchbox will need hot (often black or red) & neutral (nearly always white) power in wires and hot (again, black or red) and neutral (again, nearly always white) power out (to the light or fan) wires. Many times, these devices are wired a little differently - with just 2 wires - instead of the four cited above. This is to provide power to keep the timer motor operating. The manual for this switch can be downloaded (and printed) here.
The part number of the old switch you provided does not appear to be correct. This number lends me to believe that it is for a 220-240 volt circuit. The closest I could find to an Intermatic part number was WG230-13. This part is the timer motor for replacement on a differnt style timer. It is indeed a 220 - 240 volt clock motor as I suspected. Please double check the brand and model number once more.
Lastly, if you can not find the info requested above, you should be able to replace the old timer with the new style - provided that the installation requirements cited in the first paragraph are met. Shut the power off before removing timers and switches and test with a working meter to be sure.
I hope this helps & good luck!
Nov 21, 2011 | Intermatic Hardware & Accessories
I am replacing an existing switch/single outlet, the outlet was always live.the switch controlled a light. the existing sw was very old and only has connections on the back top.. The left had 2 white wires...
White wires under the silver screw...
The black wire under the black screw...
and the red wire under the brass screw...
If it does not work right then switch the red and black wires...
heatman101
Apr 20, 2011 | Pass & Seymour / Legrand 1595-2SWT...
that is strange
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
2002 jetta tdi died while shifting into 4th gear
Sorry, not a solution to this car but your other vw 1989 jetta...only way I could get hold of you.
here is your diagram
The following information covers electrical connections and plugs to the rear of the fuse/relay panel. It completes and supplements the information in the appropriate Service or Repair Manual for the fuse/relay panel section and should be used in conjunction with the wiring diagram for the vehicle or system in question. Volkswagen part numbers shown here may or may not match those on your panel, however, if you panel visually matches the diagram, it is correct for your application.
Fuse/Relay Panel - Rear Connections (Volkswagen Part Number 171 941 821 D) clear.gif
Connections and plugs on rear of fuse/relay panel:
A Blue 28 pin Instrument cluster wiring harness B Red 28 pin Instrument cluster wiring harness (position 5 open) C Yellow 22 pin Engine compartment/engine management, left side (position 10 open) D White 29 pin Engine compartment/wiper motor wiring harness, right side (position 6. 10, 14, 18, 27, 28 open) E Black 18 pin Rear wiring harness (position 17 open) G n/a 1 pin 10 individual circuits H Brown 6 pin Air conditioning/coolant fan relay wiring harness K Neutral 5 pin Seat belt warning system/coolant level wiring harness L Grey 4 pin Horn wiring harness L Black 4 pin Headlight/dimmer switch wiring harness M Black 2 pin Steering column switch wiring harness M Black 2 pin Headlight/dimmer switch wiring harness N Red 1 pin Separately fused circuits (glow plug wiring harness) P Red 7 pin 7 single point connectors for terminal 30 circuit R Green 2 pin Open/ECM power supply relay
Note: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market. Always consult appropriate wiring diagram for specific terminal assignments.
hope this has resolved your problem
Thankyou
Aug 15, 2009 | 2003 Volkswagen Jetta TDI
IS MAGRAY A WARRIOR KASHMIRI TRIBE?
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Dec 02, 2008 | Epson (V13H010L32) Projector Lamp for...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
