Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Lid wont open - GE Spacemaker Washer and Dryer Electric Laundry Center
My tassimo lid wont open and cant get my disc out
My tassimo lid won't open I put the milk pod in for a latte it made a noise and some milk spilt out and it won't open turned the machine off for a few days n the lid still won't open is it now broken ? As only had it for a few months
Jun 12, 2017 | Coffee Makers & Espresso Machines
My washer wont spin, it washes but then it wont start the spin cycle.....please help
what is the model number and the brand name?most likely you have a bad lid switch.it's a saftey on most washers,the factory doesn't want the washer to run when it's in spin so if you were to open the lid while it was spinning the washer would shut down,if the lid switch is broke it's like the lid is open and it won't spin or run
Jan 23, 2011 | Washing Machines
Roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Nov 08, 2008 | Roper RAS8445KQ Top Load Washer
Matsui mf160 deturgnt door wont open
hi The lid switch on a washer often serves as a safety switch. If the switch is not working, or if the switch opening in the lid is clogged with detergent the door will not open
Sep 13, 2008 | Dishwashers
1997 BMW 328i convertible
The problem is that your roof(SOFT TOP) lid isnt closing properly. If you open the roof lid you see there is a button on one of the latches that tells the car that the roof is securely closed if your roof lid is not secure the trunk wont open. To test this press down on the roof lid and the try to open the trunk.
Jun 15, 2008 | 1997 BMW 328
Chest freezer lid
Vacuum is caused by contraction of air. If your temperatures are being maintained the difference in how easily the lid opens and closes is not a point to worry about. If the lid wont shut after it is opened you do have a problem. If the lid is staying open at one corner try, with the lid open give it a slight twist pulling on the corner that is not closing fully. This action should spring the lid back to its original sealing position.
Jun 12, 2008 | Freezers
It wont finish washing
open and close the lid a few times. can you hear any clicking noises, you should hear the lid engaging the lid switch. if the machine doent think lid is closed it wont funtion( safety reasons)
Feb 27, 2008 | Maytag LSE7806A Top Load Stacked...
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
15 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
