Question about Pyle PLDN74BTI Car Video Player
No bass output in cd mode - Pyle PLDN74BTI Car Video Player
Universal remote
ANYWHERE.. Walmart, bestbuy, dollar general, even dollar tree sells them.
Apr 07, 2016 | Clarion CX201 Radio / CD / MP3 player /...
How do I adjust time on 2001 magna radio
Unknown.
Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Oct 05, 2014 | Clarion CX201 Radio / CD / MP3 player /...
Instruction Manual For Jvc
go to google and type in radio model # and should find a manual for you!
Nov 18, 2013 | JVC UX-G210 Micro system, Stereo Sound...
My amp keep going into protection mode everytime the bass is turned up,it didnt do this before.?
Chances are you have a shorted output or partially / completely blown speaker. Check all speaker output impedances. If one of them is significantly lower, disconnect that speaker/output and try turning the bass up again. If it works fine, trace that wire to the short or blown speaker. If all impedances look ok, or disconnecting that output doesn't help, then it's time to rip the unit apart and diagnose the amp.
Nov 08, 2011 | Car Audio & Video
I cant get my jl audio w6 10s to give off much bass with the jl audio 500/1 amp
here is a manual for your subwoofers: http://mobile.jlaudio.com/pdfs/8-12W6_BDS.pdf
use the wiring diagram for 1.5? (1.5ohm) with 2 speakers. the diagram for 3 speakers will not work, because it would bring the load down to 1 ohm, and the amp cannot go below 1.5 ohm.
to set up the amp:
under "preamp output section", on the "output mode" switch, select "amp filter"
to set up the levels: start with the amp gain pretty far down- with the input voltage on low for line level outputs from the deck, and on high for speaker outputs from the deck. now turn your cd deck as far up as it will go until it distorts, then turn the cd deck down to just where it stops distorting. now, you can start to turn up the gain on the amp.
on the filters, youll prolly want the cutoff filter around 100hz @ 24db slope. start with the infrasonic filters off, but, if you do get into them, try centering between 30 and 60hz on either, and, possibly dropping the cutoff filter to 80hz.
Jan 31, 2011 | Jl Audio 500/1 Car Audio Amplifier
BASS,TREBBLE,MIDS SETTING
Hello 1rocknroller,
Press the mode button repeatedly to select BASS, TREBLE, SUBW, BALANCE, FADER, DEFEAT, AND VOLUME. When subwoofer mode is set to off, it's level cannot be adjusted. If DEFEAT is set to ON, the player returns to factory defaults. Turn the volume control to adjust the setting. If no adjustment is made within 5 seconds after selecting, the player returns to normal mode.
Hope this helps.
May 29, 2009 | Alpine CDA-9856 CD Player
Amp Issues
1800W peak output at 2 ohms
975W peak output at 4 ohms
600W RMS (continuous) at 2 ohms
325W RMS (continuous) at 4 ohms
Variable LP crossover adjustable 35-250Hz
4 AWG power/ground inputs and RCA pass through
Low-pass filter
Bass boost 0-18dB adjustable remote punch bass EQ
Signal-to-noise ratio: >80dB
Line-level input
It is going into protect mode for a reason.
Disconnect the subs and turn everything on again. If the light comes on, the problem is internal and will need servicing by a technician.
Dec 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
Pyle PLDN74BTI Car Video Player Logo
11 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
