Question about LG Tone HBS-730 Bluetooth Headset- Black
My headset won't charge.
Headset is completely dead.
3 Suggested Answers
SOURCE: battery
A fully charged battery should last up to 4 hours if it's being used A LOT! But I lost mine and it was in standby mode for pretty close to 3 days and when I found it I was still able to use for quite awhile before charging it again.. So yes, it sounds like it had a weak battery..
Posted on Dec 08, 2007
  • 74 Answers
SOURCE: Have not use the bluetooth
since you have not used it for more than a year, it only mean that the battery is totally drained, you just have to be a bit patient charging it. just wait til the light gets on. if after an hour or so and it's still the same, then it's time to change the battery or the headset itself.
Posted on Aug 07, 2010
My 220 won't turn on. Red light stays on when charging but when unplugged won't do anything
The link below on page 7 has the sequence for turning on your headset (Explorer 230 and 220 work the same). If you're still having problems, then it needs to replaced.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Oct 04, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Won't take a charge
This has a non replaceable battery, you can always purchase a new headset. 84321-01 this is just the headset.
Good luck from Headsets Direct -0800-914-7996.
Aug 14, 2011 | Plantronics 510 Voyager Headset - PLN-510...
CS55 headset battery was dead (app 1 1/2 years of service). I replaced it and fully charged. Worked fine for 3 or 4 days. Now, won't charge. Tried the system reset and power cycle, no...
On your base there are the numbers 1-4. Put the # 1 in the 3 O'Clock position like a clock. Try putting the letters that are in the bottom on B.
Good luck from Headsets Direct - 800-914-7996.
Aug 10, 2011 | Plantronics CS55 Wireless Headset
The Headset Lifter won't pick up the calls. Nothing happens when I push the ear button to lift it up. I thought maybe it wasn't fully charged when I tried it yesterday. At that point, I made...
If the CS70 headset has a charge and beeps when you press the call control button, you may just need to re-pair or re-subscribe the headset to the base unit. Here is a link for the pairing / subscription instructions:
Plantronics CS70 Pairing Instructions
If the headset is not charging, the internal battery may be worn out and the headset may need to be replaced (the battery is hard wired and is not replaceable). The replacement headset is model 72910-01. Below is a link where you can purchase the replacement headset.
Plantronics CS70 Replacement Headset
Jun 24, 2011 | Plantronics CS70 Wireless Headset
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
My plantronics 220 won't turn off. The blue light won't turn off and I can't get it on or off.
Try letting the battery go completely dead on the headset and then recharge it. This should fix the problem.
Here is the link for the Plantronics 220 User's Guide.
May 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Im trying to hook up my mad catz bluetooth to my ps3 and i got it pass the scan part but it keeps saying theres a problem...PLEASE HELP
Is your PS3 seeing the Headset?
Is the headset in pairing mode?
Complete details below on how to connect it:
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be 'paired' so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Manage Bluetooth® Devices."
4. Scroll down and press X on the icon labeled: "Register New Device."
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset's LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate "8860" from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register completed"
Trouble Shooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Q. The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40 minutes. It is highly recommended to fully charge the battery before use.
Q. No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time, it may take some time for the Headset LED indicator to show charging status with a steady Red light. Make sure the PLAYSTATION 3 is turned on. The 8860 cannot charge without the console being turned on.
Q. No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters) of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
Feb 22, 2011 | Mad Catz Bluetooth Headset for PlayStation...
Solid Purple Light on Plantronics 220
Explorer 230 went into solid blue light the second time I used it. Fixed mine by letting the headset go completely dead and re-charged and it appears to work fine now.
Oct 09, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth headset
USING THE HEADSET
US USING THE HEADSET
1. Headset
2. Control Button
3. Light Indicator
4. Microphone
5. Earloop
6. Speaker
7. Charging Jack
A. Charging
Charge for at least 20 minutes before
first use. Complete charging in 2 hours.
Headset will not function when charging.
B. On/Off, Volume↑↓
Press the Control Button for 2 seconds
to power on. Press the Control Button
for 3 seconds to power off.
C. Pairing
Begin with Headset turned off.
Press button for 6 seconds. Release
button when Light Indicator flashes
blue/red. Headset is ready to pair with
Bluetooth device.
D. Pairing
Use your device’s menu to begin
pairing mode and select “320
Plantronics” on the display. When
asked for passkey, enter “0000.”
Jul 13, 2008 | Plantronics Explorer 320 Wireless Headset
Bluetooth not charging
The internal battery is bad or your charger is faulty, got a kink in the cord.
Jan 22, 2008 | Motorola Mobility H700 Wireless Headset
LG Tone HBS-730 Bluetooth Headset- Black Logo
41 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Mohamed Ismail
Mohamed Ismail
Computer Repairing
Computer Repairing
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
