Question about Peavey IPR-3000 Power Amp
My amp will not power up?
It has a breaker but will not work
  • Peavey Master
  • 1,902 Answers
Measure the breaker, measure the power switch, measure the power cable,
Posted on May 14, 2016
Some of my microphone inputs stopped working
downloads.mackie.com load this bus driver file. use winzip to install.....have fun meder's tv service
Aug 28, 2012 | Mackie 2404-VLZ3 Mixer
My adam A3X is suddently having the power switch stuck. I can no longer turn it on.
As loon as the power switch is not also a circuit breaker, just change the switch. If it is also a circuit breaker then there probably is some problem with the amp.
May 27, 2011 | Adam Audio A3X 2Way Studio Monitor...
Hi, I own the Dynaudio BM6A acoustics monitors & I want to know if there is a circuit breaker system inside the monitors, for surge protection? The reason I ask is because I have no power conditioner...
If an internal circuit breaker pops, something has failed. Even surge protectors do little to protect stuff unless they are high level types with filtering. Key thing: ALL your interconnected equipment MUST be powered from the SAME receptacle or power conditioner. Using multiple outlets can allow building "ground bounce" to rupture sensitive input circuits. Use of balanced lines avoids noise in systems.
Apr 21, 2011 | Dynaudio Acoustics BM6A MK II Active...
My Orange amp recently stopped working, as in no sound
Likely the power amp section has had a failure. There are likely several bad components and it will take an experienced electronics person to weed out all the bad parts.
The light has little to do with the condition of the unit. It MAY only indicate that power switch is on or that one of several voltages from a power supply is present.
Mar 24, 2010 | Orange Rockerverb Rk100htc 100watt...
Is there a circuit breaker
There should be a fuse holder near the place in the back of the amp where the power cord plugs in. Also some Marshalls have fuses in fuse holders on the circuit board. Always replace with the same value and type as the original fuse. Never open up the amp when it is plugged in to the outlet. When replacing the internal fuses do not touch the capacitors as they retain a lethal charge. If the fuse continually blows it is an indication of a more serious problem which will require servicing by a qualified repair person.
Jun 25, 2009 | Marshall Amplification Marshall MG250DFX...
Crate amp blew a house fuse and stopped working. pilot light still works and I can get a distorted signal through the headphones if I play a guitar very loudly through it.
When a piece of equipment causes a fuse to blow or a breaker to trip, it normally means something in the equipment's circuit was shorted. Either because of heat, moisture, a loose screw, loose wire, loose part, a bug, etc. For safety reasons, don't plug it back in and take it to a repair shop.
Hope this helps!
Jun 04, 2009 | Crate Music
Amp will not come on
hi thanks for using fixya!!
On this error, you should check still the built in breaker.
Apr 21, 2009 | Peavey Pv 2600 Power Amplifier
Peavey IPR-3000 Power Amp Logo
110 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
