Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Whirlpool gu3200 dishwasher no power - Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
3 Suggested Answers
  • 14 Answers
SOURCE: whirlpool GU3200 dishwasher
The illusive technical repair sheet that isn't there...
Turn the thing a little further and pull UP. It'll come out. You've got to put some muscle into it!
The manual for the GU1000/1200/1500 is here (it's almost the same and as close as I can get you to a 3200)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
Jeremy
Posted on Dec 29, 2007
heatman101
  • 43501 Answers
SOURCE: Our whirlpool dishwasher, gu3200 is leaving food
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 27, 2011
HOW TO RESET MY DISHWASHER
All you can do is turn the power off at the power point, leave it for a few minutes and then switch the power back on.
Jan 11, 2016 | Dishwashers
My Whirlpool dishwasher was running when there was a power failure, and now there is no power whatsoever. The power failure happened when the machine was on final rinse and drain. Water is still in the...
Most Whirlpool manufactured dishwashers have a thermal fuse, located inside the operator console. When tripped, the dishwasher will not run. A power outage can cause the thermal fuse to trip. It cannot be reset and has to be replaced, if bad. Please post back with your COMPLETE MODEL NUMBER (located around the door opening) so I can determine the configuration of your dishwasher and explain how to access any potential fuses. -->
May 19, 2011 | Whirlpool Dishwashers
My GU3200 dishwasher is not cleaning properly; trying TSP in varying amounts did mot work, nor did running a vinegar cycle. I can see food residue in the filter, but how can I access the filter? It seems...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 15, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Our whirlpool dishwasher, gu3200 is leaving food residue on the dishes. We have taken it apart, cleaned everything, rinsed it with vinegar and the arms are rotating...yes the problem still persists. Any...
heatman101
Jan 22, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Purchasing this Whirlpool dishwasher
probably a new one. lifespan is 10 years average
Apr 05, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My whirlpool dishwasher keeps tripping the power off. Do you know what the problem could be?
hmmm...I would check the electrical power connections at the bottom of the dishwasher for melting or burning....otherwise it sounds like there is a short in the wiring of the dishwasher somewhere and would hve to be traced out.
Jul 28, 2008 | Whirlpool Dishwashers
Noisy motor
It could very well be the wash pump motor starting to fail. It could also be something as simple as food and debris clogging the intake to the pump. The main wash pump is used to circulate water during the wash cycle. If the intake to this pump is clogged with debris, it can exhibit louder than usual noise during operation and lower water pressure. This particular model also has a chopper assembly just prior to the pump intake. This chopper can dice up some food particles, but cannot process things like popcorn kernels, tough pieces of meat, celery, etc. Basically, anything hard, fibrous, or tough. If you go to searspartsdirect.com, theres an illustration of the pump assembly under the "Pump and Motor Parts" heading. The chopper is item(s) number 6 & 8. If anything gets caught in the chopper it will not provide enough water flow for the main wash pump. Double check the pump sump reservoir and make sure it is all clean. If it still exhibits the same symptoms, the motor may be damaged. I hope this helps you. Let me know if you need further assistance.
Jun 15, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool GU3200 dishwasher
Jeremy
Nov 23, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool from ikea DWF415
hazman, depending on your serial number, this model has a bunch of service issues. Everything from the motor rework to the heating element. Sounds like your issue has to do with the heating element. If the dishwasher does not detect a 4 degrees temp. rise in the water in will go into this fault. They have redesigned the board to bypass this fault in later models. Since I don't have a serial number I can't tell if you have one of the affected models, but I assume so. I would call Whirlpool and inquire about any service flashes they have on this dishwasher, you may be covered. Otherwise you would have to do some tests to determine the cause, starting with the heating element. I believe you can clear the fault by pressing these keys in this order: high temp-air dry-high temp-air dry. four key presses...this should put it in the automatic test mode. Let it do it's thing and the fault should clear. For more info on your dishwasher there should be a tech sheet behind the bottom toe panel....Catriver..post back.
Jan 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
