Question about Canon PIXMA iP3500 Printer
Nothing will print, ink is full, paper goes through as if printing?
  • 3 Answers
SOURCE: printing blank paper
try a few things, your printer maintenance my need to be adjusted, such as settings. i have one at work and i hate it, canon printers are so non-user friendly. do you have both a black and a color cartridge in it, if so you will have to tell it in the maintenance settings, if you only have one or the other installed you have to put both in it wont print with only one cartridge. if you just bought it and still have everything that it came with...take it back and buy a lexmark.
Posted on Jul 25, 2008
  • 153 Answers
SOURCE: Canon Mp480 wont print!
you have a purge unit problem, if you have done a few cleans then throw machine away cost more to fix it. but a new printer
Canon tech
Posted on Apr 01, 2009
herbalgarden
  • 344 Answers
SOURCE: Hi,I am experiencing nothing printing on paper
your print head is either clogged or damaged, A print head is the unit your ink cartriges sit in. If its a nedw or newer printer (under warranty) you can contact the manufacturer and they will send you a new print head at little to no cost-good luck
Posted on Dec 19, 2009
arjoy
  • 95 Answers
SOURCE: Black ink cartridge is new but not printing
Was the code of the cartridge you put is correct? if not then replace it.if it is right, then check the nozzles, the printer heads and clean. some printer is equipped with cleaning tools software that might help you.
Posted on Jan 20, 2010
  • 85 Answers
SOURCE: Printer has ink, but nothing comes out on the paper.
You might need a new print head. If the printer is older maybe a new one would be cheaper.
Posted on Apr 19, 2010
My Canon Pixma MX882 is not printing though lots of ink. Paper goes through when I press print on my PC but nothing is printed
Print a test sheet to see if the printer is OK. If tthe sheet prints fine has this printer worked on this computer before? Did you change anything or update anything? You may have the wrong driver installed or the cable could be defective if it has worked before.
Feb 02, 2015 | Canon PIXMA Office Equipment & Supplies
Printer ink cartridges full but nothing comes on the paper
Try those solution:
- Clean the head within the printer maintenance mode.
- If you filled the cartridges by yourself, make sure that you empty the cartridges of air after filling it with ink!
Mar 18, 2012 | Office Equipment & Supplies
Making noise like its printing but nothing comes onto the paper
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jan 21, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
Will not print on paper
if the cartridges were out of the printer for any length of time the ink has dried up on the print heads. you most likely will have to replace the ink cartridges. then allign again before it will print correctly
Apr 04, 2010 | Lexmark JetPrinter Z22 Color InkJet
Hi,I am experiencing nothing printing on paper even though ink cartridges have been replaced and cleaning has been performed.ink absorber warning appears and says that absorbers are almost full and to push...
Dec 19, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Printer prints nothing - it's speaking to the pc, it sounds like its printing, the paper goes through but comes out blank. Any ideas?
Check for the inks. If they are still full, try taking them out and clean the printhead as some ink got dried and blocked the passage where the ink goes out. Also, it would be wise to shake the ink cartridges to distribute the ink evenly.
Oct 25, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Nothing prints out on paper.
Did you remove the little sticky tabs from each new cartridge? They allow air in, and ink out.
Have you removed the tear off tape from top of cartridges, it lets the air in and ink flows.
May 28, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Canon tech
Mar 30, 2009 | Canon Pixma MP480 All-In-One InkJet...
Canon PIXMA iP3500 Printer Logo
22 people viewed this question
old marine
old marine
