Question about Harman Kardon AVR 130 Receiver
How do i find optical input on my harmon kardon avr 130?
SOURCE: harmon kardon avr 25 II
hey i also had this problem, i don't know the name of these but they are basically plugs that you have to block output from the front rear and center speakers of the white/red cables... sry for bad description but its on the left side when looking at the back of the receiver, while all of the other speaker wires should be hooked up to the right with the twisting knobs... it took me forever to find this out but yeah it was a simple fix
Posted on Oct 30, 2007
  • 16 Answers
SOURCE: Voltage Spike / Power Surge Harman Kardon AVR 130
In this case is pretty hard to give a diagnostic. There are plenty of possibilities. It has to be seen by a tech
Posted on May 24, 2008
SOURCE: cannot get dts from my Harmon Kardon AVR 300 via my Blue Ray
I'm not sure if this solution is still necessary however:
I own a H/K AVR300 and have a PS3 hooked up via HDMI to the TV and Optical TOSLink to the receiver. I have no troubles selecting between DD 5.1 and DTS 5.1. I can even select trueHD whatever format but I can't detect an audible difference, I think that mode might be downgraded back to regular DD5.1...
Hope this helps...
Posted on Jun 10, 2008
  • 308 Answers
SOURCE: how can i make the sky remote control th avr 130
Does the sky remote have a code for the HK receiver? If it does, use that code to program it. Most other remotes won't work completely because this receiver uses a seperate button to turn it off...
Posted on Mar 15, 2010
  • 9 Answers
SOURCE: Just bought a Sharp LED TV and there is a slight
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Posted on Jan 31, 2011
Access optical 2 source
I think you are looking for an optical in input on the rear panel of the receiver.
Dec 27, 2014 | Harmon Kardon Harman Kardon Avr 140 6.1...
Hook sound surrond
You probably have to select the optical input from the menu for sources of your component connection. Most receivers allow you to select optical, coax, or plain PCM right/left audio.
Oct 15, 2013 | Harmon Kardon Harman Kardon Avr 135 Home...
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
How can i make the sky remote control th avr 130 (harmon kardon)
Mar 14, 2010 | Harman Kardon AVR 130 Receiver
Fiber optics input not working
you will likely have to access the harmon kardon setup menu and direct the fiber input you are using toward the video or audio source selection which is being utilized along with it
Feb 22, 2010 | Harman Kardon AVR 7000
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
Audio problems using a Playstation 3
First try ensuring that "OPT 1, 2, or 3" function is selected depending which one you are using on the H/K 146 (see manual for selection instructions). Next please ensure that the PS3 audio out set to "optical" (Settings/sound settings/audio output settings/digital out+DD 5.1). That should help.
Dec 05, 2008 | Harman Kardon AVR 130 Receiver
HI, I just purchased a Samsung LCD and connected my Optical Cable directly from my AVR 20 to the TV but get no sound...it is set for Video 1 but I am told that should make no difference and should contact...
Connect the optical audio OUT on the TV to the optical audio IN on the receiver. Turn the receiver on and set it to input as it was labeled on the connection ("video" or "auxillary" or such). Turn the TV on and set it to an active TV channel (with video and presumably audio info), not to VIDEO 1.
If you continue to have a problem, please provide an update.
Nov 30, 2008 | Harman Kardon AVR 130 Receiver
Apr 05, 2008 | Harman Kardon AVR 130 Receiver
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
Harman Kardon AVR 130 Receiver Logo
41 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
