Question about Lexmark Office Equipment & Supplies
956.02 error code in DVT0149
To be continue,power of,10 seconds,power on.
I have a proplem in konica minolta bizhub c352 how to sort the problem i have an error code 3451
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. ENSURE YOU WAIT THE 10 SECONDS
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jun 15, 2016 | Konica Minolta bizhub Office Equipment &...
Bizhub c352 error 3451
Printer showing error code 3802
To resolve the error:
  1. Upgrade your printer firmware to the latest version:
    1. Locate and select the firmware for your printer.
    2. Follow the instructions to install the firmware.
  2. If your printer firmware is already up-to-date:
    1. Press the On/Off button on your printer control panel.
    2. Disconnect the power cable from the back of the printer.
    3. Wait 10 seconds to allow the printer to reset.
    4. Connect the power cable to the printer.
    5. Turn the printer on by pressing the On/Off button.
  3. If the error continues:
    1. Open the printer access door.
    2. Remove and install the printhead.
    3. Close the printer access door.
    4. Follow the on-screen instructions to calibrate the printhead.
      NOTE: If you are not prompted to calibrate the printhead, turn off the printer, wait 10 seconds, then turn on the printer
Feb 03, 2015 | Kodak Esp 3250 All-in-one Inkjet Printer
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
Bizhub error code
Have the fusing unit replaced. One attempt only to reset if you continue to get the code the machine can catch on fire! That would ruin a perfectly good day. If the code comes back after this procedure have a qualified Konicaminolta Service tech look at it.. First power off the machine with both switches. Wait 10 second turn on the switch inside the machine then holding down the Utility/Counter button turn on the second power switch on the control panel keep the utility /Counter button down until you get Trouble reset then touch get a OK then power off the machine wait ten seconds power back on.
Jun 26, 2013 | Minolta Office Equipment & Supplies
My printer ESP5210 is showing error codes 3501,3606,3507. What can i do to fix this
To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
for more help visit https://cbrtechsolutions.net
Sep 29, 2012 | Kodak Esp 5210 Inkjet All-in-one...
Wm3431 pf code
The PF error code indicates a power failure. This might occur while machine is working due to an external disturbance like a storm or power outage in the area. If the PF error code is displayed, turn off the power to the washer, unplug it for 10 seconds, and restart the wash cycle. If the error code continues to present after these steps have been taken, then the washer may require service.
Apr 26, 2012 | LG WM3431 Front Load Washer / Dryer
I am getting a pf error code. the washer does nothing
Hope helps.
Sep 15, 2011 | Washing Machines
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
PF CODE COMES UP WHAT IS LIKELY PROBLE
Found the below at http://lgknowledgebase.com
hope this helps,
best of luck, have fun,
thanks,
chuck
Feb 25, 2010 | LG WM1814CW Front Load Washer
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
