Question about Liquitex Slow-Dri Fluid Retarder Acrylic Additive-4
Service info.Scania R420 retarder
Oil&filter change check oil level
How much oil does a 94 corsica 3.1 v-6 with filter hold
My info for engine oil and filter change, 4.5 quarts. You could put in about 4 quarts, start the engine let oil circulate, kill the engine, let the oil settle for a bit, check oil level on dipstick. Add oil to the full mark on dipstick, hopefully the dipstick is correct.
I looked at info on chevy Corsica.
Apr 03, 2017 | 1994 Chevrolet Corsica
Service time Scania R470 and what grea of oil do we use
will depend on the weather conditions and driving conditions
the service intervals are in the user manual or you can simply call a scania service dealer and ask them
Jan 24, 2017 | Cars & Trucks
How many litres of oil does a i998 grand prix 3800 take
Are you talking about engine oil? My info says 4.7L with filter change. Check the level on dipstick, when adding oil. Making sure the oil level is proper, is your responsibility.
Your owners manual may have this info.
Apr 07, 2016 | 1998 Pontiac Grand Prix
What would cause my cars engine to freeze up and no longer run
No oil or oil pressure , also check all belt driven components like alternator or a/c compressor or power steering pump and water pump one of listed items could seize and cause your engine not to turn over aka crank , not much info given on make and model of vehicle
Apr 07, 2016 | Cars & Trucks
On the Mercedes C-240 the oil sencor light came on with the A service oil change .I had the oil changed and now the oil level light comes on. And this is on a 2005 C-240 4-matic .
Could be the person who changed it never ran the motor and then topped it off once the filter was full. Have you checked the oil level after you let the car sit overnight to make sure the oil level is on full? I would say it could be a bad oil level sensor, except that the coincidence of coinciding with an oil change is too obvious.
Sep 14, 2014 | 2005 Mercedes-Benz C240 Classic
What does service b mean
The A service and B service is an oil change and a long list of inspections. Unless the service is covered under warranty, or this is a new car and you want some piece of mind, I suggest only getting the oil change. The rest of the "service" consists of someone looking for problems with your car. Here's what's included:
A SERVICE (~ $205.95 + tax) :
- Inspect and record tread depth, and correct tire pressure
- Rotate tires (excludes AMG, Sports Models, SLK, and vehicles with staggered wheels)
- Engine oil change and oil filter replacement
-Includes Mobil 1 synthetic oil
- Lubrication service
- Includes hood hinges, lock cylinders, striker
plates, sun roof tracks and top off all fluids
- Cooling system inspection
- Includes antifreeze protection level, hoses and
clamps
- Brake inspection
- Includes check of pad thickness and condition of
discs, fluids and lines
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional. Dust filter prices vary by model)
- Function check
- Includes warning lamps, headlights, exterior
lights, seat belts, windshield wiper and washer
- Inspect and lubricate throttle linkage
- Check and clean air filter
- Reset flexible service system counter
B SERVICE (~ $379.95 + tax) :
- Inspect windshield wiper inserts and service windshield washer system (Replacement of wiper inserts additional*).
- Inspect and rotate tires, record tread depth, and correct tire pressure. (Wheel balance additional*).
-excludes AMG, Sports Models, SLK, and vehicles
clamps
- Brake inspection
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional*. Dust filter prices vary by model)
- Function check
- Inspect front axle ball joints; check steering play and power steering clutch; and rear differential levels
- Inspect Poly V-Belt for condition
- Inspect starting and charging system and service battery
- Inspect climate control refrigerant
Feb 12, 2013 | Mercedes-Benz C-Class Cars & Trucks
Had an oil change about a month ago and about 5 weeks later motor is gone. No oil light came on, no oil leaks
WELL NO OIL LEAKS.WARRANTY MIGHT COVER IT BUT YOU NEED TO SHOW ALL OIL CHANGE RECEIPTS.ALSO YOU HAVE TO USE GM MOTOR OIL LIKE 5W - 30 VALVOLINE USE GM OIL FILTERS.THEY WILL CHECK TO MAKE SURE YOU BEEN KEEPING UP WITH SERVICE MAINTENANCE AND SERVICE SCHEDULES.CHECK YOUR OIL LEVEL ON DIP STICK SHOULD BE AT FULL MARK LINE. THE CHEVY COBALT LS LT LTZ 2.2 ENGINE HOLDS 5.0 QUARTS OF OIL WITH NEW FILTER AND CHEVY COBALT SS SC HOLDS 6.0 QUARTS WITH NEW FILTER.IF OIL LEVEL LOOK OKAY.CHECK ON INTERNET FOR ANY RECALLS OR ANY TROUBLE WITH EARLY OIL PUMP FAILURE.
Aug 17, 2010 | 2006 Chevrolet Cobalt
Have '70's Partner R420 chainsaw. What's the
The Oil:Gas ration for a Partner 420 saw is 25:1 if using standard, quality two-stroke air cooled oil. The service manual says 40:1 can be used if you are using Baird/Poulan branded 2-stroke oil designed to be run at 40:1.
Please rate this solution on FixYa!
Thanks
Mar 30, 2009 | Garden
Liquitex Slow-Dri Fluid Retarder Acrylic Additive-4 Logo
41 people viewed this question
Top Reeves Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Reeves Vehicle Part and Accessory Expert? Answer questions, earn points and help others
