Question about Bosch HBL 755 Stainless Steel Electric Double Oven
Unlocking doors is displayed and bottom over light will not go out.
I have cut off the circuit breaker for five minutes to reset, but the display still indicate unlocking doors and the bottom over light does not go off.
2 Suggested Answers
  • 2069 Answers
SOURCE: Bosch HBL755A . Time on display continally blinks
now, Turn the oven off at the circuit breaker and wait for more then 5 minutes and then turn breaker back on.this will reset the oven.this is the only way to reset.but if you have tried this same procedure and this did not help, then it might be the problem with door switch or door assembly.
it got burn't and due to this the door latch is stuck and its not releasing the door and so, unlocking door message comes up.
for more detailed trouble shooting please click on this user manual link directly here
You can get required parts from here
Posted on Jan 04, 2011
How do you reset the control panel on an a mana oven model number AOES3030E
The easiest way would be to throw your circuit breaker, wait 10-15 minutes for good measure, to clear capacitance, then flip the breaker back on. If the display is damaged or dim, get the display board re-built.
Sep 30, 2014 | Amana Ovens
Frigidaire door lock won't reset
Hello Steven Krenz - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Apr 02, 2013 | Frigidaire GLEB27S7A Electric Single Oven
Oven door display comes on
Hello mapatt - Are you able to open or latch the door? Try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. This will clear most false error codes. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs. The unit could possibly be experiencing a wiring failure, faulty light switch, door latch or EOC.
Jan 26, 2013 | Frigidaire 27 in. Electric Double...
Frigidaire oven door is still locked 7 hours after self-cleaning
Hello - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the range back on. This will clear most false error codes. If error code still displays on panel, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty light switch, door latch or EOC.
Oct 21, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Gas range says dr how to fix it
Hello robin_deathe - Will the door look? Is the door lock indicator light glowing? Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately one minute and turn the range back on. This will clear most false error codes. If error code still displays on panel, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty light switch, door latch or EOC.
Oct 02, 2012 | Frigidaire Ovens
I used the self-clean for the first time and my oven door is still locked and the display doesn't work at all. Model #YKESS908. What can I do to unlock the oven door? I have checked the circuit...
Hi
You can set the unit on self cleaning and then after 15 minutes stop the cycle, let it cool down for an hour and then open the door. If the issue remains then you'll have to replace the door lock assembly, then you can open the door with a coat hanger by pulling the latch towards you. Hope this helps...please post back for further assistance.
Daniel
Sep 09, 2011 | KitchenAid Ovens
Oven won't light and the display is flashing E1 F1
HI. This is essentially a board code(EEPROM check-sum error). Use this check procedure to confirm failure.
1. Safely disconnect the power from the affected unit for five minutes.(Shut of the appropriate circuit breaker or unplug from the wall)
2. Re-apply power and observe for at least one minute.
3. If the code re-appears, replace the main control board (also called ERC or clock).
Jul 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The controls aren't working. the digital display
Turn off the circuit breaker that controls the oven.
Wait for a minute and then turn the breaker back on.
If the display comes back, reset the clock.
If it doedn't come back, and is still scrambled, you will need to call a service tech.
Nov 24, 2009 | GE Ovens
Display is flashing0.00 and auto. oven won't work
Try turning the oven circuit breaker off for a minute then back on. Reset the clock and see what happens.
Nov 22, 2009 | Fisher and Paykel AeroTech - OS302M...
Thermador oven display fc
Try turning off your circuit breaker for a few minutes. Then, after you reset it, push clear, then set your clock.
Sep 11, 2009 | Thermador SMW272 Electric Double Oven
Bosch HBL 755 Stainless Steel Electric Double Oven Logo
27 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
