Question about Pioneer CDJ-200 CD Player
Can you reset a cdj - Pioneer CDJ-200 CD Player
How to reset pioneer cdj 850-k
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
Nov 06, 2014 | Pioneer CDJ-850-K Multi-Format Digi Deck...
CDJ 1000MK2. CDJ pitch control is out of calibration. The pitch plays at zero when the slider is at what should be the slowest setting. How do i reset zero to the middle of the slider.
There is a fine adjust on the pitch control circuit board, however if it is staying at Zero at the extremes then it's time for a new pitch control :(
Jun 25, 2011 | Pioneer CDJ-1000 CD Player
There is a disk stuck in my pioneer cdj-800 on the track display it say 00 e-9101 and i cant eject from deck
hii there,
Please look bottom (turn ur CDJ 180 degree) there will be a pin
to eject the disc from ur CDJ. Also make sure when u do it ur CDJ must be turn off.
thx
djajay
Aug 06, 2010 | Pioneer CDJ-800 Turntable
Is it possible to do a factory reset on a CDJ1000? (pitch issue)
There is no mention of a factory reset in the Mk1 service manual. The firmware can be upgraded - Mk1 & Mk2's need to go to Pioneer / Videotec, Mk'3 can be upgraded from CD.
http://www.pioneer.co.uk/uk/support/software/CDJ-1000%20MK3/index.html
The pitch may just be faulty, look here for a replacement :-
http://stores.ebay.co.uk/methleykev
Jul 18, 2010 | Pioneer CDJ-1000 CD Player
How reset cdj 800
You Cant reset a cdj but you can update the firmware look this up on youtube or something!
Jan 18, 2010 | Pioneer CDJ-800 Turntable
Stanton c.304 cdj reading disk but cant go bno futher
Check the sled motor is operating correctly.
Aug 05, 2017 | Stanton C.304
Plugged cdj-800 and mixer into a European outlet-now they won't turn on
ok, remove screw under the cd mixer and slide down carefully the top of the cdj and then trace where the power cord connects in to circuit(there is a fuse there try to change anew one..thats is!
Aug 11, 2008 | Pioneer CDJ-800 Turntable
Cdj 100s
hi! my pioneer cdj-100 has not ejecting cd
Feb 23, 2008 | Pioneer CDJ-100 Turntable
Cdj 700
hi
error E-9101 is notifying that there is dust in the system
get the drives professionally cleaned and reset the units
D
Nov 20, 2007 | Pioneer CDJ-700S Turntable
Pioneer CDJ-200 CD Player Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
