Question about Konica Minolta Office Equipment & Supplies
How to change the image transfer belt on a konica
  • Konica Minolta Master
  • 6,680 Answers
Well a model number would help
Posted on Jan 22, 2016
2 Suggested Answers
  • 14 Answers
SOURCE: Have a Konica Minolta magicolor 2350 with "paper
try to look the lever...near in transfer belt, or try to repl. the sensor
Posted on Oct 15, 2013
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
8650 machine error 21
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
Hope fully not the last two expensive.
Jun 04, 2014 | Konica Minolta bizhub C250 All-In-One...
How can solve error p 5 idc sensor in konica minolta bizhub c450
P5 front IDC sensor failure.Wipe clean the surface of the transfer belt if it is dirty with a soft cloth or change the transfer belt unit is damaged.Reinstall or reconnect IDC sensor shutter or connector for every color unit and clean the sensors when vacuum cleaner after remove the all imaging units and the transfer belt unit.
Mar 25, 2014 | Konica Minolta bizhub Office Equipment &...
The machine status of my konica minolta is p21, what does this mean?
P 21 Color shift test pattern failure.Relevant electrical parts is the image transfer belt unit.
Wipe clean the surface of the transfer belt with a soft cloth if it is dirty.Change the image transfer belt unit if the transfer belt is damaged.Clean the 2 sensors located upper side of unit.
Apr 18, 2013 | Konica Minolta Office Equipment & Supplies
Ineo +200 status p 6 and p 21
P-6 : Cyan imaging unit failure
P - 7:Magenta imaging failure
P -8 :Yellow imaging unit failure
P -9:Black imaging unit failure
Select Imaging Process adjustment - D Max Density and if the setting value is negative readjust.
Check the drive transmission portion of the imaging unit and correct as necessary,clean theIDC registration sensor windows if dirty,clean the contact of the imaging unit connector if dirty,check the high voltage connector for proper connection.If necessary change the image unit or the image transfer belt unit.
P -21 : Color shift test pattern failure.
Wipe clean the surface of the transfer belt with a soft cloth or change the image transfer belt unit if the transfer belt is damaged.
Feb 21, 2013 | Konica Minolta Office Equipment & Supplies
P-27
P - 26 1st image transfer ATVC black failure
P - 27 2nd image transfer ATVC failure
P - 29 1 st image transfer ATVC colour failure
Check the transfer belt unit contact and that of high voltage board for connection and clean or correct the contact.
Change the image transfer belt unit.
Clean the sensor windows on the transfer belt unit.
Feb 10, 2013 | Konica Minolta bizhub C450P Laser Printer
What is error p-21 of konica minolta bizhub c250?
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
Jan 22, 2013 | Konica Minolta bizhub C250 All-In-One...
P-21 error of c250
4 Change PRCB.
How to solve model c360 konica minolta the printer displaied change image transfer belt
There are two ways to solve this issue, First you can replace the whole transfer unit or you can install a new un blown fuse to rest the internal counter.
Nov 19, 2010 | Konica Minolta KONICAMINOLTA Transfer Belt...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
