Question about Singer Sewing Machines
Speed controller not working - Singer Sewing Machines
I have an old elna lotus sp sewing machine and need to reduce the speed on the foot control is this possible
The Lotus should have the integrated foot controller and power cord in one. Some of these had a switch on the foot controller which reduced the power to half speed. That's the only way to adjust the speed other than the foot on the pedal. The later models Air Electronic have a slide speed control on the front face of the machine which made life easier.
May 06, 2017 | Elna Sewing Machines
Viking rose 609 model foot pedal will not work
I would suggest you replace the foot pedal speed control.
Jan 10, 2017 | Sewing Machines
I would like a wiring schematic for the speed control transformer and light on a old Necchi Mira sewing machine, please.
the light wires are not to be connected to the speed control but have a separate circuit to the on / off switch
if you have the light connected to the speed control then as the resistance to the motor is decreased it affects the power available to the light
May 31, 2016 | Necchi Sewing Machines
I have a brother sewing machine modelHSQ9185. It was working fine but all suddenly it has no speed. Motor in running at slowest speed. What'sd wrong with it?
quite likely the speed control in pedal decided it was tired . have lost a couple myself lately , these new digitals do not last like the old carbon arc type did
Sep 11, 2015 | Brother Sewing Machines
How do I slow the speed of the machine down in order to quilt
use a smaller stitch. DO NOT PUT YOUR FOOT ON THE PEDAL SO HARD
Jun 28, 2015 | Sewing Machines
What is the difference between a variable and non-variable speed sewing machine foot control?
variable foot control==the farther you push it...the faster the machine goes....
non variable....only has stop...and run....
Jun 05, 2015 | Sewing Machines
Singer 670 2 speed variable foot control. Slower speed no longer works. Blown resistor we think. Any one any idea what size it should be?
I believe you're referring to the 6700 series of machines. I found another foot controller at Sewing Parts Online for $79.00. You might also keep a lookout on eBay; enter "Singer 6700" as a search term. You can often get gently used or even new parts there cheaper, but I didn't find your foot controller right now. Here's the link to Sewing Parts Online. http://www.sewingpartsonline.com/foot-control-singer-6700-sers-sewing-machine.aspx
Jan 17, 2015 | Singer Sewing Machines
Bernina 1000 can i add speed control?
Yes you can replace the foot control if it is no longer regulating the motor speed of your machine.
Jul 15, 2012 | Bernina 1008
When I step on one side of my foot pedal the machine works, but pressure on the other side does not turn the machine on.
That foot pedal had a feature of High speed on one side of the pedal and low speed on the other. Either your speed control unit inside the pedal is slightly burnt or the spring inside the pedal has moved out of position slightly. Even dirt could be the culprit if it found it's way into the speed control unit inside the pedal.
Oct 07, 2009 | Husqvarna Viking 1
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
