Question about Cambridge Audio 640C
Radomly clips or skips
My 640C randomly clips or skips.  Not quite a skip and dosn't happen in the same place twice.  Happens on new CD's.  Ran Lense Cleaner disc and still happens.
  • dcmaconachie Nov 08, 2007
    I have the same problem, my player is only 6 months old. Sometimes it can get through 2 or 3 discs and refuse to read the next one, but as you say, no predictability to it. Guess it needs to go back to the manufacturer? This is already my 2nd one (first had the top line of its LCD screen missing).
  • Anonymous Jul 14, 2008
    1 year old machine; can go dozens of discs with no problem, then clips 'n' skips. Hitting the back button takes you to the start of the track, and the problem is not duplicated. Completely random. Last time it happened was April, happened today (July). When I replace it, it won't be with a Cambridge Audio product as a result - some of us can't afford the luxury of paying for shoddy components.
I have exactly the same thing. I am on my second one too.
Mine is an australian model purchased in Sydney.
Posted on Dec 15, 2007
SOURCE:
CD player skipping
Make sure the unit is mounted level and not to secured that its pinching down on the unit
Jul 23, 2012 | GE 7-5295 Undercounter DC /Radio Combo -...
1989 jeep cherokee skipping problem
it may not be the problem but check the earthing strip or put a new earth wire from the engine block to the shell or negative on the battery and see if this stops it, can happen if the earth is damaged or not connecting properly, as parts not getting the correct voltage.
Dec 04, 2017 | 1989 Jeep Cherokee
Kenwood portable cd player dpc-741 skips.
Hello
The skipping happens because the lens is weak,to solve this problem open the cd player so you can see the lens.Clean the lens with cotton wool dabbed in a little methylated spirit(wipe carefully).This should stop the skipping.
If the skipping continues then the lens is too weak to play CD's so it is best that you change the lens of your CD player.
Aug 11, 2010 | Kenwood Audio Players & Recorders
Bose Wave Radio skips CDs
it seems taht motor that spins the cd is going bad.
Jan 31, 2008 | Bose & Wave& Music System
My benz in trunk cd changer skips....
Hi if you have cd lense cleaner try run it twice so that the small particles stick it lense will be remove .
also put some rubberized foam cushion around the cd if buit in.
Jan 30, 2008 | Sony XR-C6100 CD Changer
Cursor skips lines while typing
I had this problem and solved it in minutes by downloading and installing a neat little freeware program called TouchFreeze. Google it and give it a try. --Erik E./Brooklyn
Jan 21, 2008 | Sharp Dell Inspiron 8200 15.0 ASV UXGA -...
Skipping yamaha 765
I have a very similar type unit, a Nakamichi CDC-3 that had the same problem. I found this link....
http://repairfaq.ece.drexel.edu/REPAIR/F_cdfaq6.html#CDFAQ_001
I spent about two hours fixing mine. The sled mechanism was binding somehow, causing random skipping. The first 10 minutes was getting it apart and figuring what was wrong, the remainder was spent getting all those tiny parts back in the proper place.
Look up the exact symptom before going at it (probably long skips). Set aside a long slow lazy day with nothing to do. DO NOT drink too much coffee, you will be handling tiny parts that go in tedious locations, so you don't need caffeine jitters adding to your misery. Take your time and be careful. It's well worth it. Mine plays like a new one.
Nov 26, 2007 | Yamaha CDC-585 5-Disc CD Changer
CD's are skipping
try cleaning the laser diode with an alcohol-soaked swab. be careful not to use too much alcohol or to press too hard against the diode lens.
May 30, 2007 | Sony CDX-F5710 CD Player
Cambridge Audio 640C Logo
231 people viewed this question
Top Cambridge Audio Players & Recorders Experts
Don Hart
Tom Chichester
Kerry Cunningham
Are you a Cambridge Audio Player and Recorder Expert? Answer questions, earn points and help others
