Question about Kenmore Elite 38 Bottle Dual-Zone Wine Cellar
Temp set at 74 - Kenmore Elite 38 Bottle Dual-Zone Wine Cellar
My thermostat show 74 degrees as a current room temp...but we have it set at 70 and it's probably 65 in the house. ..the only way it will turn on is if I put it 74 or 75????
The old white-rogers thermostats with a mercury switch are adjustable. snap the face off. In the center you will find a plastic slot screw. set the indicator to the actual room temp.
Other type ? Replace the thermostat
Mar 01, 2015 | Heating & Cooling
Refrigerator
Unplug it for 2 minutes to do a hard reset. If it does not reset check the temperatures with a thermometer if the temps are off by more than 5 degrees your temp sensors are out of range
Jul 25, 2013 | Refrigerators
Air condistiong isnt cool to set temp
system needs to be charged check filters and coils to make sure they are clean first could be an air restriction problem something blocking your intake
Jul 28, 2012 | Heating & Cooling
I am staying at my daughters house and the a/c is not coming on. I tried overide but keeps going back to 78 as temp. I want 74.
When you select the temperature on this t- stat its will say 74 degrees the it goes back to 78 because thats what the room temp is at. Hunter is a very cheap brand of t- stat and also confusing. Here is what I would try move the temp to 74 then look for a hold button select that see what happens.
Jul 21, 2011 | Hunter Heating & Cooling
I have a White-Rodgers programmable thermostat. I have it set to go to 74 degrees at 11:00 PM. It has started going to 74 at between 10:00 and 10:30 PM. If I press run it goes back to the daytime temp...
Hello I assume its cooling program.Probally the thermostat has a recovery mode.In another words the thermostat will come on EARLY to make sure you are at (74*f at 11:00).Maybe try 11:30 start time and see if that helps or disable energy recovery mode.
Jun 17, 2011 | Heating & Cooling
Supply air is 74 degrees???????? low side
Because you have a ductwork problem. Look for leaks in the supply lines or a dirty coil not allowing sufficient airflow.
Jul 31, 2010 | Ruud UBHC Air Conditioner
It making a humming sound and the fan is going around slow the temp in home is 74 the set temp is 65 so it should not be running what could be the problem ruud upka-035jak is model
If you are running A.C.,and the T-stat is set at 65,and the room temp is 74,the A.C. will run until the temp goes down to about 65 or so.Turn T-stat to 76 and the unit should shut down. Also,check furnace filter for dirt, and check condensor unit coils and see if they are dirty.If condensor coil is dirty it cannot breathe properly. That will cause the compressor, and the blower motor to overheat.Wash cond. coil down with water hose to clean .Start at top of coil and go sideways,slowly going down.
Feb 23, 2010 | Ruud Matching Split Air Conditioner
It is 110 degrees out, we have set the central air for 70 but we can not seem to get the temp under 74 degrees, the unit is always running is it just too hot out for the unit to keep up, or is something...
You probably hit the nail on the head. You are currently getting 36 degrees difference in temp. That's pretty darn good. Most units would struggle with that. Running all the time is usually an indication that the unit could be somewhat undersized too. 74 degrees is not that bad under those conditions.
Jul 30, 2009 | Whirlwind FH-778 Air Conditioner
Kenmore Elite 38 Bottle Dual-Zone Wine Cellar Logo
24 people viewed this question
Top Kenmore Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Kenmore Furniture Expert? Answer questions, earn points and help others
