Question about Polaroid T730 Digital Camera
My camera works until i put the sd card in - Polaroid T730 Digital Camera
2 Suggested Answers
kenshin99
  • 89 Answers
SOURCE: Card error
Hi!
I wish what I'll be saying will resolve the problem. Unfortunately, your camera can only support up to 1GB of SD card. That's the reason why the 4GB card is not working.
Here's a screenshot of the details regarding your Polaroid camera.
I hope that helps.
Good luck and have a nice day!
Posted on Nov 27, 2008
New 164GB SD card when put in to either of my 2 cameras a message reinsert card appears on screen. No further operation can be done until card is removed. Can this problem be fixed?
The 64 GB cards are not SD cards. They are SDXC cards and need a different interface. The card lloks the same, but the electronics is different. Your camera or any device you are using should be SDXC compatible.
On this page, scroll down half a page and look how the compatibility works for SD, SDHC and SDXC.
What SD Information SD Card Panasonic Global
Apr 01, 2015 | Cameras
My camera doesn't see SD 16GB anymore. Worked fine until a few days ago. SD works fine on PC
Try inspecting the memory card slot, eventually with a magnifying glass. Sometimes just a little bit of dust, a small paper or other debris, can block data transfer. Be sure al contacts on the card, but also in the camera are clean and shining. Never use sharp tools in or around a camera. Don't scratch the contact points.
And to make sure you can put pictures on a memory card, there must be space. If possible try to format the card in the camera. Just to make sure the camera sees the correct file system on the memory card.
Dec 15, 2013 | Panasonic Lumix DMC-FZ28 Digital Camera
My camera has been great until the other day. It won't recognize that the memory card is in the camera and keeps saying the memory is full. I had downloaded the card's contents and after that it...
Yes you need a new SD card, it is rare but happens where the SD card malfunctions and it is not read by the camera, it happened to me and I put in a new card and it worked find.
Jul 03, 2011 | Cameras
My sd card wont read. it says that its not initialized. i flipped the thing in the sd card but nothing changed. how do i get my card to work. it worked fine until i put the sd card in the printer over...
Had you ever initialized (formatted) the card, especially when you first got it? If not, an unformatted card will work fine initially, but almost always corrupts with time after many pictures are added. To prevent this issue permanently, you should always format a new card. But note formatting will erase the card! If you haven't saved your pictures yet, and you're having trouble locating them on the card with your computer, see this article. After you've recovered and saved your photos, format the card IN THE CAMERA using the camera format feature (look for it in its menus). This will rejuvenate the card, and prevent this from happening again.
Jan 09, 2011 | Cameras
Memory caed error please check the card
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Jul 18, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Camera says that my sd card is locked and it isn't
try to put some glue on a your card lock , in unlock position. But be carefully do not delete your picture by accidentally.
May 31, 2010 | Canon PowerShot A710 IS Digital Camera
Screen is green once I put memory card in
just happened to me. I had not pushed the sd card all the way in until it clicked. Also, if the card has been formatted on another camera, it won't work. try a new card and push it all the way in and it should work.
Dec 30, 2009 | Digital Concepts Cameras
SD Card Error
The NV10 works with MMC and SD cards, 2GB and smaller. It will not work with higher-capacity SDHC cards.
May 02, 2009 | Samsung NV10 Digital Camera
Svp t-100
lol u have to put the card in before u turn it on... most cameras do that...
Aug 13, 2008 | SVP HDDV-2500 Camcorder
Polaroid T730 Digital Camera Logo
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
