Question about Frigidaire Heating & Cooling
Remote control stopped working on 6500 btu ac frigidaire
5 Suggested Answers
gripfitter
  • 557 Answers
SOURCE: need to know voltage for this product
115v AC
Posted on Oct 02, 2009
  • 31 Answers
SOURCE: We just bought a frigidaire 22000 btu unit. We we
If you have or know someone how has a multi meter just test that you have 220 volts at the outlet. Thats about the only way to tell. The fan will run if you only have 120v at the outlet, just not the compressor. so it will not cool. If you only 120v at the outlet it could be just a fuse or breaker problem. If it's a new outlet then it could be wiring wrong also.
Hope this help
Dan
Posted on May 22, 2010
SOURCE: indoor a/c remote control will not work. How do I manually
If you lift the filter cover, on the right you will see a wiring diagram. Above the diagram and to the left , you will see a small hole that is about a fourth of an inch in diameter with a rod in the middle. Touch the rod and the unit will come on AUTO. Touch it again and the fan will reduce speed. One more time and it will go off.
Posted on Jul 13, 2011
  • 4736 Answers
SOURCE: I've got one single 12000 btu ac unit and one
Taking apart the hand held remote won't serve any real purpose as none of the parts inside are replaceable. Since you have 3 different units, with 3 different hand held remote. I'm wondering, if perhaps, you're using the wrong remote on that one unit. As each one has a different remote code.
In addition, I have learned from experience, that if the display screen on the hand held works, the problem is not in the hand held. Now, that's not to say, Operator Error can't play a role in it. But, most times, it's the receiver in the unit,that may be causing the problem. Or the hand held is to far away or something is blocking the signal in between.
Almost every appliance we sell, has a radio frequency remote control. The most problems we incur is with weak or dead batteries or operator error. The problem with batteries is that you don't now how long they sat in a warehouse, before making to a retail outlet and then how long they sat on the shelves there, before they were sold. They may have enough power to activate the handheld remote, but not enough to transmit a strong signal. So, check the strength of the new batteries you installed.
Hope this helps and thanks for choosing FixYa.
Posted on Jul 29, 2011
My frigidaire AC starts cooling fine but stops blowing cold air after few minutes and it does not cool at all. I haved turned it off and re-started it and it does the same thing
The compressor is being prematurely turned off. That explains why the cooling stops after a few moments. Either the thermostat is responsible or the electronics working with the therm are responsible for the anomaly.
Freon level is fine because it does cool when compressor is running. U might also want to check the start/run capacitor. That sucker starts the motor and keeps it running after the start. If the run section goes bad the motor will usually stop after it starts.
Aug 17, 2016 | Frigidaire FAS256R2A 25,000 BTU Window Air...
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
I need codes for AC Frigidaire for Quality QTH 4000 universal remote cotrol
Since you do not have the code for your Frigidaire AC just aim remote control at AC press for 6 seconds and release SET key until ac open automatically, then press ENTER
Aug 03, 2013 | Philips Universal PH301S Remote Control
Remote stops working
Both remotes are operating on the same frequency - usually you would think that having two products of same manufacturer would be a good idea, but in this case, the remotes interfere with each other.
Feb 19, 2008 | Philips HTS-6500/37 System
Heating & Cooling Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
