Question about Nakamichi Audio Players & Recorders
Cd player does not play the #1 track and gets stuck
Its a OMS-5II and it plays sometimes and usually does not play the #1 track and then sometimes skips and sometimes when I push play it wont...
ice man
  • 68 Answers
SOURCE: Player only plays first 3 tracks on CD and then stops
the emitting diode is not shiffting right..it might need some cleaning of its track..open it and check it out. good luck
Posted on Apr 25, 2007
bluenadas
  • 203 Answers
SOURCE: cd tray mechanics
It can be repaired but in all of my years in consumer repair, I dread the CD/DVD tray alignments the worst.
There are many things involved in getting them to operate without fail. Using the mfgs documentation you can get them up and running but most of the time they failed because something is amiss to begin with. So you spend an hour getting everything setup and it will work once or twice but them fail. Only to find out that a location sensor is bad or a gear is missing a tooth....
Posted on Nov 21, 2007
SOURCE: CD player skips on early tracks
The lens assembly in a CD player glides along on a two rail track, kinda like a railroad track except tubular. The lens carriage is moved over this track by a small motor driving a worm gear. (Think long, tubular and spiral). If the rail tracks or the worm gear dry up or have dust accumulating on them, this could be the cause. Normally they have a light gear oil or lithium grease on them to keep them lubricated.
Posted on Mar 10, 2008
  • 31 Answers
SOURCE: B&O Beosound 1
Hi, It may be that the brushes on the CD spindle motor are getting dirty. A relatively easy fix, IF you know how to open a Beosound 1 without causing damage. I used to work in a B&O Authorized Service Center, and I suggest contacting the one nearest you first for an estimate. Most "normal" shops are most likely not prepared to handle the sometimes complex disassembly/reassembly issues.
Posted on Sep 17, 2008
  • 223 Answers
SOURCE: stuck cd discs
I think there are a couple of faults here. The first one is maybe a faulty motor on the eject mechanism. The second one is a faulty laser unit as it is not scanning the disc. Hope this helps.
Posted on Oct 05, 2008
Cd not able to play last few tracks knocking sounds
CD Mechanism is possibly faulty. Sometimes won't track the outside of the disc properly. Try other CD's of about the same playing time, if more than 1 disc does it, the fault is usually the mechanism. (If the disc is a lot longer than the standard max CD length 0f 74 minutes, some players may have a problem with them. This was usually with older generation players, so may not be applicable here.)
Nov 26, 2013 | Cambridge Audio Azur 650C
Dvd player dv692h hangs after 1hr of play
Hello
Check the CD for any defect. Hold it against light and see whether there is any tiny spots. If the CD is faulty this kindl of fault can occur. OK.
Jan 09, 2012 | Televison & Video
I have a Kenwood music system (quite old ) cd player DP-322 after you load the disc it sometimes just plays 1 track or doesn't play at all if you open the draw and then close it and select random play it...
you need to have the lazer lense cleaned by a pro or buy a lens cleaning cd and load it about 5 times i think youl find it will fix your problem
cheers
sonic boom electronics australia.
Apr 21, 2010 | Audio Players & Recorders
CD skips in CD player
you can get a compatible laser unit on local electronics store.
Jan 17, 2010 | Audio Players & Recorders
Player stops mid track and shows ''no disc''.
HELLO
Have you tried cleaning the lens? It's incredible how a dirty lens can cause so much grief! You'll need the CD player cover removed and powered off then get some isopropyl alcohol and a cotton bud. Wet the bud but not too much get any excess moisture off.
Using a careful circular motion clean the lens, let it dry and try the player again. If this does not cure the problem, you may have a defective laser and that will need replacing.
ALL THE BEST (:-)
Oct 04, 2009 | Audio Players & Recorders
After approx 1/2 hour of play the movie gets stuck for few seconds, plays again for 2-10 seconds, then permanently gets stuck. Sometimes a smack to the machine works, ff does not work....we usually just...
Smacking the machine is a good way to destroy the DVD lens. Get a CD/DVD lens cleaner and make sure there aren't any marks on the disk. Dirt & smudges cause about 75% of all CD/DVD player problems.
Feb 27, 2009 | Toshiba SD-2150 DVD Player
Player will only play track #1
Maybe your "play once" option or "repeat" option is activated, try and check it and get it back to normal play...
Dec 03, 2007 | Memorex MPD8506 Personal CD Player
NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Nov 06, 2007 | Audio Players & Recorders
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Colin Stickland
Colin Stickland
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
