Question about Kenmore 73952 Gas Dryer
How do you remove a fuse from a 110.64872400 kenmore dryer 80 series
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 80 series Dryer: Door Light stays on and wont start
Posted on Mar 05, 2009
gamefixer
  • 6 Answers
SOURCE: Kenmore 80 series electric dryer will not start even though the door switch switch appears functional and power is getting to the timer.
Easy fix. I had the same problem on mine. You need access to the back. Remove back cover. Look at bottom left, you will see two blue wires going to a white plastic item next to one of the thermal sensors. This white plastic piece is a fuse, or fusible link if you like. I'm not sure what the rating is, but you can take the old one to a parts store. They can match it. Now, why did it blow? Well, if the dryer is old, it could be just worn out. But more than likely, one of your 230 volt lines has degraded due to a bad connection, thus drawing more amps, thus blowing the fuse. Look at where the power cord comes in at. Is there any discoloration or oxidation at the terminals? If so, replace the power cord at this time, and try to clean up the terminals as best you can. Also, at this time, you probably better take a look at the lint collector duct running along the left side down the back. It's probably so clogged with lint that your dryer does't dry as fast anymore, and air flow from the exhaust is restricted. Take the duct off and clean it out, or blow it out with compressed air. You should be up and running now. Have fun...
Posted on Jun 16, 2009
  • 97 Answers
SOURCE: Kenmore 80 Series gas dryer starts with heat but very short time
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
  • 2341 Answers
SOURCE: I have a used kenmore 80 series dryer. It will
could be bad motor
Posted on Nov 07, 2009
hunter19_46m
  • 7482 Answers
SOURCE: can't find kenmore 80 series dryer drum belt
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Also for a manual I will include this website:
http://www.applianceaid.com/
Good luck,
I hope this helps
Posted on Nov 16, 2009
Testimonial: "many thanks... sounds like a lot of work unlike my old dryer"
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
My kenmore dryer 80 series will not start please tell me were to look for the duct fuse
if its the one like on the picture, take off front bottom panel and remove lint filter cover, the fuse sits on top of blower housing on left side!!!
Jun 24, 2011 | Kenmore 63942 Dryer
I have a Kenmore 80 series 110.70812990 won't start!
first ceck the door switch,if not thatunplug remove back and check the long white main fuse to your left-mike
Feb 24, 2010 | Kenmore Dryers
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore 80 series elec.dryer will not start.have power to outlet.is there a fuse ??
There is a fuse :) If you pull out the dryer from the wall and unplug it Then yopu remove back panel.Once you have panel off at the bottom left corner there is a small white fuse with 2 small blue wires going to it.Good luck
May 06, 2009 | Kenmore 73952 Gas Dryer
Location of the thermal fuse on the kenmore gas dryer 80
Feb 03, 2009 | Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore 73952 Gas Dryer Logo
24 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
