Question about iRiver H320 MP3 Player
H320 USB connect problem
When I connect wall charger it shows i'm connected to PC via USB. all functions disabled. will a new battery solve problem.
3 Suggested Answers
shivam4529
  • 150 Answers
SOURCE: H320 20 GB MP3 Player will only charge when connected by USB cable to PC
follow this process
right click on computer then
1. click properties
2.hardware
3.device manager
4.universal serial bus controller(open the + sign)
5.click upper one double click
6 go to driver
7.click on the update driver
8. then choose second one (advanced) then next
9.click don't search
10.then next next if it is over
Posted on Jun 17, 2008
  • 3 Answers
SOURCE: iRiver H320
Hi all,
The problem is to do with the Firmware you loaded onto the player, it may be a buggy version.
The way to get around the (always connected to USB) is to either short out pin 1 & pin 4 on the players mini USB port or cut the USB lead & touch the black & red wires together for a few seconds & then that will allow the player to come out of USB mode & then boot into the iRiver firmware, then all you need to do is re connect the player back to your pc & re download the Hex file & use the players menu to update the firmwate again.
Then you player should be fine.
Regards Tom.
Posted on Jan 17, 2009
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
Tip
How to convert a USB Battery Charge Cable to AC
<p>Many of the new battery-operated devices such as phones and MP3 players come with USB cables to charge the battery while the computer. However, wall chargers for these items are missing, damaged or undelivered. If so, you can use a USB wall charger, USB cables, adapters and because all have the same size at the end with these boots are endless. <br /> <p><br /> <p>Generic Battery <br /> <p>1. Buy a USB wall charger. These are available online through www.amazon.com and www.bixnet.com or a limited number of electronics stores like Radio Shack or Best Buy. <br /> <p><br /> <p>2. Connect the USB end of cable to the USB wall charger. <br /> <p><br /> <p>3. Connect the charger to the USB cable. Then connect it to the wall. The machine starts working the green light. <br /> <p><br /> <p>iPod Battery <br /> <p>1. Connect the USB cable to the iPod. Be sure to press the two ends before inserting it into the iPod. If you do not, you can damage the pins, once that happens, you will not be able to charge your iPod. <br /> <p><br /> <p>2. Mount the USB wall charger sliding the top in half, for the manual. <br /> <p><br /> <p>3. Connect the USB cable for both USB wall charger. Plug the wall charger. The costs start when the lights come back on the iPod screen and you will see the battery icon fill. You can find this anywhere iPod charger are supplied. <br />
on Aug 09, 2011 | Apple iPod touch
Iriver h320
http://www.misticriver.net/forums/h3xx-series-320-340/11314-fixed-h320-always-connected-prob-2.html
solved
Sep 13, 2008 | iRiver H320 MP3 Player
IRiver H320
http://www.misticriver.net/forums/h3xx-series-320-340/11314-fixed-h320-always-connected-prob.html
solved
Jul 17, 2008 | iRiver H320 MP3 Player
follow this process
1. click properties
2.hardware
3.device manager
6 go to driver
Jun 17, 2008 | iRiver H320 MP3 Player
Iriver H320
there is a setting somewhere that stops it charging when you connect it to a usb port on the computer.
May 08, 2008 | iRiver H320 MP3 Player
Charging system
If your phone won't charge via your computer using a USB cable or via your pickup via a car charger, will it charger via the regular travel charger (i.e., plugged into the wall)? If it won't charge that way either, then the issue is with the connection or with the battery. If you replace the battery and it still doesn't charge, then the problem is with the connection. If this is the issue, then I would suggest replacing your phone, especially if it is 2 years or older. If it is a new phone and under 12 months old, then I would suggest getting a warranty replacement from your provider. If it is older, and you don't want to replace it, then try gettin a new battery, however, if it still doesn't charge, then like I said previously, it is the connection and it would be less expensive to replace the phone then to repair the connection. Hope this helps and let me know if you need any additional information.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Feb 11, 2008 | Nokia 1100
Charging Battery
did u try to charge it connected to your pc? maybe its the charger
Feb 04, 2008 | Motorola Mobility Moto Q
IRiver H320 fails to power up
I too have that problem, or it insists I remove external battery, I went onto the official site and they were no help. I've not really tried this link, but somebody told me to try it maybe it's a battery fault http://www.hyperbattery.com/indexmain.htm Hope this helps, if so let me know The_Ultimate_Power@hotmail.com Ste
Oct 01, 2007 | iRiver H320 MP3 Player
Mini ipod freezing showing charger sign
restart your pc press del key in your keyboard,
go to setup usb settings disable usb 2.0 setting
Sep 15, 2007 | Apple iPod mini M9160LL/A MP3 Player
iRiver H320 MP3 Player Logo
44 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
