Question about Video Game Consoles & Games
What dose the word deseption mean
I need it because need it for towmarrow
What dose it mean if the srs light is on
srs light mean suplementary restrain system or air bag if light is on means you have a problem need to scann system to correst the problem
Oct 07, 2014 | Cars & Trucks
P0500 code what dose it mean
check the wires at the speed sensor, depending on what unit you have its usually on bottom of rear transmission. I just replaced mine, must have been a stick that hit it and broke the plug.
Sep 02, 2014 | Arctic Cat 2013 Prowler 700 HDX
My asus laptop has no screen display and can sense flash disks
First you thing to check is when you turn the laptop on it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max. If it dose beep then take a normal PC monitor and connect it to your laptop and see if that works. if it dose work then it means that the screen is busted or you should pess the screen buton on the keyboard
Nov 02, 2013 | ASUS Eee PC 1000H Laptop
When it says LINE ERROR what dose this mean
That indicates that there is static or interference on the phone line. You will need to call your phone service provider for them to test the line.
Feb 11, 2010 | Office Equipment & Supplies
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What dose e13 means
error, code 13 for service man
Oct 04, 2009 | Black & Decker Heating & Cooling
Wat dose it mean when your battery sign on ur sk is a thermometer
means your battery has gotten to hot to charge, take if off the charger for a few and try again.
Jun 09, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Hotpoint ultima
F1 means short circuit motor triac.
You need to call an engineer.
Oct 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
