Question about Rowenta DX6700 Iron
Cord not making contact , iron will not heat
The ball at the base of the cord is not making contact as it moves around causing the iron not to heat.
bestdarngood
  • 3037 Answers
SOURCE: Iron heating sporadically and sensor lights working sporadically
sounds like a loose connection in the power transfer, some piece of metal may be broken or the cord itself may be damaged in some place, you could try replacing the cord. I would just go and buy a new iron. They aren't all that expensive anymore. Good luck with whatever you decide to do. I hope you solve your problem. If you want any further help or have any other questions, please let me know, otherwise have a Good Day.
Posted on Mar 29, 2008
  • 2318 Answers
It looks like the cord has a loose connection and will need to be replace.
  • 96 Answers
SOURCE: iron turns off by itself while using it
you may have a bad connection in the cord wires will need a new cord replacement or new iron
Posted on Dec 14, 2009
SOURCE: Rowenta Iron-Professional Luxe The power cord
I drilled out the nubs in the center of the screws. removed the screws, and took off the back plate. The problem is that the cord seems to be abraiding when it swivels, and eventually wears thru. It seems like a fire hazard and should be looked into by Rowena. Anyway, I cut out the damaged cord and reattached it. Problem fixed..
Posted on Dec 19, 2009
heatman101
  • 43501 Answers
SOURCE: My Rowenta iron will only heat when plugged into
Sounds like the plug and/or the cord are bad...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
Leaking water around base
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
God bless you
Feb 03, 2013 | Rowenta Irons
Tip
If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
The first thing to check is to make sure that you actually have electric power getting to the steam iron. Many times the problem is simply caused by a tripped circuit breaker, a faulty outlet, a worn or broken plug on the end of the cord, or in some cases, a fuse that is in the plug. Another common problem is for the cord of the clothing iron to break at the point where it enters the handle of the iron. By checking that you have power actually getting to the internal parts of the electric iron, you eliminate one set of common problems.
Next you need to check that the power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If the power can get to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
If your iron is getting too hot or not hot enough then the problem will almost always be in the thermostat. Sometimes it may be a simple thermostat calibration problem, but it also can be that the thermostat simply will not work properly anymore.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter.
on Jul 14, 2010 | Irons
Iron will not heat
see the causes and proceed according, fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 22, 2012 | Rowenta Irons
Will not heat
see the causes and proceed according. fix it. God bless you
Sep 22, 2012 | Rowenta Advancer Iron
I am told the problem is with cord and they point at the and they point at the base of a beautiful iron.
Usually the cord at the base breaks off, because of tension from too much moving and pulling!
If thats problem u could cut the appropriate length and screw again the end of the cord!
Dec 03, 2010 | Rowenta Powerglide DE011 Iron with Auto...
The electrical cord is very hot at the point where the cord enters the iron
mcdevito75 here, You may have a problem with the heating element in your iron, Check to see if you have a Warrantee if so, return the iron to Black & Decker. In the meantime look for an appliance repair shop in your area and have the iron checked out.
Aug 07, 2010 | Black & Decker Prestige Plus Premium X830...
Iron has light on so power is there however iron
You will need to dismantle your iron. Follow the instructions below to locate the fault:
a. Make sure the power cord is not damaged.
b. Then, check the temperature selector. If it is in the correct position, something else is wrong.
c. Check the thermostat. As you disassemble the iron, clean the lint from the thermostat. Then test it with your ohmmeter. Set your ohmmeter on RX1 and clip the probes onto the terminal. Take a piece of wood or plastic and move the contacts open, then closed. When it closes you should see the ohmmeter just from high to zero. It so, it is working well.
d. Test the heating element. Do this by removing the base of the iron. There you should see the probes. Take you ohmmeter, set on RX1, and touch the probes. If it reads between 10 to 25 ohms, it is working correctly.
e. If you have an electronic iron, the only other possibility is the circuit board. If you have exhausted your options, take the iron to a professional.
Thank you.
Sep 28, 2009 | Irons
Turns on, flashes yellow but never heats up
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jan 12, 2009 | Rowenta Effective DX1900 Iron with Auto...
Why isn't my Iron heating up? will not heat
well..let's check the plug..is it firmly in wall, and ** problems with the part going into the unit, as well?
does the light that shows power work on the panel, under the handle?
has the unit dropped recently?
Mar 10, 2008 | Rowenta Powerglide DM273 Iron
Rowenta DX6700 Iron Logo
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
