Question about Texas Instruments TI-30X-IISTK Scientific Calculator
Adding a 5 at end of problem - Texas Instruments TI-30X-IISTK Scientific Calculator
What is the best social media monitoring tool only for Facebook?
As for Social Media Marketing tools, every social media have their own tools for the Marketing/Business purpose because all social media created on different algorithms.
Here, ask for Facebook Social Media monitoring tool. Facebook marketing tools for business to promote their brands and reach customers. The expense cost of Facebook marketing is very low, rather than other social media.
Some features of Facebook Monitoring tool-
1. Filter By Ad Positions
2. Complete visibility
3. Narrow Down Your Searches
4. Data Of Millions Of Ads From 15+ Countries
5. Bookmark The Best Ads and so on.
Dec 09, 2017 | Best Computers & Internet
Trying to port forward a web port, media port, and phone port to an ip address for security camersa
1. Select Port Forwarding/Port Triggering under Advanced in the main menu.
2. From the Service Name list, select the service or game that you will host on your network. If the service does not appear in the list, see the following section, "Adding a Custom Service."
3. In the corresponding Server IP Address fields, enter the last digit of the IP address of your
local computer that will provide this service.
4. To the right of Server IP Address, click Add. The service appears in the list in the screen
To define a service, game, or application that does not appear in the Service Name list, you must first determine which port number or range of numbers is used by the application. You can usually determine this information by contacting the publisher of the application or user groups or newsgroups. When you have the port number information, follow these steps:
2. Click Add Service (see Figure 5-1 on page 5-7).The Ports-Custom Services screen displays.
3. In the Service Name field, enter a descriptive name.
4. In the Service Type field, select the protocol. If you are unsure, select TCP/UDP.
5. In the Starting Port field, enter the beginning port number.
• If the application uses only a single port, enter the same port number in the Ending Port
field.
• If the application uses a range of ports, enter the ending port number of the range in the
Ending Port field.
6. In the Server IP Address field, enter the IP address of your local computer that will provide
this service.
7. Click Apply.
See the rest of the manual here.
http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf
Dec 26, 2013 | NetGear WNR2000 Wireless Router
50 cc scooter adly wont turn over with electric ignition
Hi Anonymous and the usual suspects are:
1. Ignition switch not in the "ON" position.
2. Engine run switch in the "OFF" position.
3. Discharged battery, loose, corroded or broken battery cables, especially the "NEGATIVE" cable at both ends (solenoid chatters).
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day. Untitled Document
Jan 08, 2012 | 2008 Adly Jet 50
Give examples of noun derivative
noun derivative - a verb that becomes a noun by adding a suffix.
You sometimes come across words which have been derived from their roots by adding certain structures like prefixes and suffixes.
In your earlier years of schooling, you must have been done with exercises and development activities on the use of prefixes
A prefix- is a group of letters added before a word or base to alter its meaning and form a new word. In contrast, a suffix is a group of letters added after a word or base.
5 Example of prefixes:
Prefixes MEANING EXAMPLES
ana- up, back, again analogy, anatomy, anagram
anti- against antipathy, antiwar, antisocial
apo- from, away from apology, apologize
com- with, together communal, community
con- with, together connect, confide conspire
there are so many example of this. i hope it helps. remember that an adjective derivative is a noun, verb and adjective that becomes an adjective by means of adding affixes.
In this lesson, you will deal with deriving words through the use of suffixes.
A suffix added to the end of a root word.
5 Example of suffixes:
Suffixes Meaning Example
-ics things having to do with optics, physics
-ism the belief in pacifism, terrorism, socialism, communism
-logy study field of biology, geology, etymology, cardiology
-or, -er one who takes part in doctor, actor, teacher, driver
-sis act, state, condition of analysis
We have, for example, a verb that becomes a noun by adding a suffix.
This is called a noun derivative
A noun that becomes an adjective by adding a suffix is called an adjective derivative
Example of Adjective Derivative:
subject- subjective
addict- addictive
react- reactive
success- successive
care- careless
ugly- ugliness
hope- hopeless
steel- steely
accept- acceptable
obey - obedient
These are but few ways by which we can identify how words are derived.
Jun 13, 2011 | Macromedia Computers & Internet
Whining from rear end only when turning
If you have had the oils changed in the car,the wrong oil was put into the differential.It has to be for a limited slip diff.OR a friction modifier has to be added.Once the oil is changed,or modifier added,go to a big carpark(empty) and at full lock on the steering turn the car in figure 8's.Then do it in reverse.about 5 times each way.This spreads the diff plates with the correct oil and it should fix the noise.Do all this at very slow speed.Hope this helps
Aug 16, 2010 | 2000 Jeep Grand Cherokee
I have SONY ERRICSON F305 and iam not able to down load themes for it
All low-end SE devices (S302,S312,F305,F395 etc) are made by SAGEM. They come with 5 pre-installed themes without option adding more themes.
Oct 15, 2009 | Cell Phones
How to add & change the incoming message tone of samsung i780
Adding mp3 text message tone:
1. sync it w/ Windows Mobile Device Center ( Windows Mobile 6.1v )
2. go to FILE MANAGEMENT & click BROWSE THE CONTENT OF YOUR DEVICE
3. click the storage of Samsung not the STORAGE CARD
4. open APPLICATION DATA folder
5. open SOUNDS folder
6. paste the desired message tone ( mp3 file )
7. end...
Apr 17, 2009 | Cell Phones
Grease fitings locations
Most vehicles come from the factory with no provisions for grease to be added. If you are lucky, you will find small 5/16, "plugs" in moving front end parts (tie rod ends, ball joints etc) which can be removed and replaced with zirk fittings, to allow proper service. If components are "sealed", as they wear out, replacement parts will have fittings.
Feb 22, 2009 | 2003 Dodge Ram Maxi
Texas Instruments TI-30X-IISTK Scientific Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
