Question about Vacuums
Simplicity vacuum My vacuum just cut off and now it wont start. I pressed there restart button but nothing happens
  • 1,673 Answers
Could be a bad cord or a switch problem. Could also be a problem with the motor. Will have to checked to find the right problem.
Posted on Feb 17, 2008
If my Oreck Magnesium upright needs a new sensor, what might it cost to repair?
Try pressing and holding the start button for about 15 seconds and see if the vacuum re-starts. The power board would probably run you somewhere between 3$35-$50 plus labor if your machine is not still under warranty. If it is still under warranty, it should cost you nothing.
Sep 10, 2015 | Oreck Vacuums
No power what do I do when I stopped and tried ti start again no power . Emptied it and cleaned filter but still not working
All vacuums generate heat and some have automatic cut off switches when the vacuum does overheat. When this happens the manufacturer does not want you to just turn it back on, they want you to know there was a problem and to let it cool down. They often do this with a restart button. Having to press a restart button is supposed to make you think a bit more about the problem and, perhaps, let the motor cool down before restarting the vacuum. The button is often small and red.
Sep 15, 2014 | VAX Appliances Vax X3 Bagless Upright...
Simplicity symmetry vacuum stopped working
There is a reset button on the back that trips if the vacuum gets hot.
Jul 27, 2014 | Simplicity Vacuums
Why won't my Roomba start when I press a green "clean" button?
Bad PC board. Throw it away. Robot vacs are nothing more than novelties ( expensive toys ) They may do what you want them to do at first but they never last very long and other than brush replacements they are not repairable. If it is within the warranty period you can get a replacement with that.
Jul 01, 2017 | Roomba iRobot 630 Vacuum Cleaning Robot
Dirt devil canister power wand wont work
first find and locate belt if in good shape prolly aint bad and may be motor lock up
Nov 11, 2012 | Dirt Devil Vision Cyclonic Canister...
My Miele Vacuum s5980 power cuts in and out?
Go to support on the Miele website. Enter your model number and search trouble shooting for your solution.
Aug 02, 2012 | Miele S 5980 + SEB 217 Bagged Canister...
Simplicity F3500-- how do I get the bottom off to change the belt?
To change the belt on the Simplicity F3500, unplug the vacuum and turn it upside down. There are two tabs (one on each side) behind the beater bar that hold the cover on the vacuum. Press these tabs inward and lift the bottom plate away from the unit.
Then remove the brushroll and the worn or broken belt from the pulley on the side of the brush roll and the drive shaft. Loop the new belt over the driveshaft and the brushroll. Replace the brushroll in the housing and turn it by hand. Make sure that the belt is seated on the driveshaft and pulley with no twists. Also check that all of the rotating parts will move.
Then put the bottom cover back on by aligning the back hinges and then pressing the plate down until both sides click.
For pictures of the cover removal process, look at page 15 in the manual. The direct link is . Most Simplicity vacuum manuals are available at their support site: .
I hope this helps.
Aug 11, 2011 | Simplicity 7250 Deluxe Vacuum
Vacuums Logo
424 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
