Question about Dewalt Dw936 18v Cordless 5-3/8"136mm Circular Saw 2 Dc9096 dw9116 Charge
My dw936 when trying to cut just goes slow and gets stuck and stops,why?
Why doesn't it cut anymore it just goes slow then stops
Why won't it cut anymore?
Not a lot of information here so I'll take a guess. If the chain isn't turning it can be frozen in the bar. The chain can also be too tight that keeps it from turning or your oiler may be plugged and not working and without lubrication it will slow the chain down.
Aug 21, 2015 | Garden
Prop spins when out of water but when i put it in the water it slows down to a slow creep
yes very common, have you hit a rock as some stage or maybe it is wearing out but as soon as some pressure goes on the prop the shaft will spin normally but the prop is now no longer held to the shaft correctly hence your problem. Check it by marking the prop and shaft with a straight line then put it in the water, take out and check your mark they probably wont line up anymore. Solution...get a new prop. I have a different way to get these fixed but it is not recommended I drill a self tapping screw into my props just until it hits the drive shaft then stop just enough pressure to keep to stuck to the drive shaft
Apr 09, 2014 | Minn Kota Riptide St Saltwater 55 Bow...
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Ok I have a chevy c1500 1991 5.7 v8 2wd. I was driving home the other day and out of no where the truck was giving gas uncontrollably. I had to use the breaks to slow down and once I got home I had to...
Check the vacuum hose that goes from the intake manifold to the brake booster sounds like it may have a hole in it.The vacuum leak will cause your motor to idle high and it also will cause your brake very hard because with out vacuum from the engine the brake booster will not work.
Feb 15, 2012 | 1991 Chevrolet K1500
When using the keyboard, every time i click the letter b on it, it causes Window's Media Player to open. But the Ctrl key on the left side doesn't allow me to use short cuts in my programs anymore...
Sounds like your cntrl key might be getting stuck..
A couple of things you can do. you can take the key off, and clean round the key. And Believe it or not, you CAN put the keyboard in your dishwasher, but you have to shake out the left over water and let it sit for about 4 days.
Also try a good dust cleaner to see if that will help.
Jul 16, 2011 | Logitech Computers & Internet
WHEN I START TO RIDE OFF IT GOES SLOW AND THEN FAST WHAT IS THE PROBLEM .IT START SOMETIME .WHEN I SLOW DOWN PUSHING ON THE STOP IT CUT OFF
You mean sometimes it wont get out of its own way and other times runs like a bat out of hell from a stop ? Sounds alot like a bad Mass airflow meter or it isn't shifting down into first gear. Try manually selecting low gear when you start out and see what happens. Also low fuel pressure or very restricted fuel filter can do this too.
May 02, 2011 | 1992 Cadillac DeVille
The chain slows down or stops when cutting. The engine runs fine and doesn not slow down. I checked the oil, cleared the oil vents to the chain, the brake is fine and is not causing the problem. The...
THE SAW IS RUNNING FINE . WHEN THE CHAIN STOPS AND THE ENGINE IS STILL RUNNING AT HI THROTTLE THE CLUTCH MAY BE WORN AND SLIPPING. PULL THE CHAIN AND BAR AND SEE IF THE CLUTCH HOUSING IS BLUEISH IN COLOR IF SO I WOULD REPLACE THE CLUTCH
Sep 17, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
N64 cartridge stopped working
try blowing inside the cartridge then cutting the game off then on if that dosnt work the cartridge dosnt work anymore happened to me plenty of times
Aug 03, 2009 | Nintendo 64 Console
Riding mower goes slow in forward speed
There is a variable speed pulley that is a double pulley....one belt from engine to pulley and one from pulley to transaxle....remove both belts...pushing in the clutch will help with removal....remove o ring on top of pulley and pull up......the middle piece of metal is stuck....this piece is meant to slide up and down.....put the middle piece of metal on your pulley in your vice...wd40 the hell out of the shaft on pulley .....grasp the top with one hand and the bottom with your other hand...work the stuck pulley free.....put lithium grease on shaft...reinstall....done
Mar 09, 2009 | Mtd Garden
Dewalt Dw936 18v Cordless 5-3/8"136mm Circular Saw 2 Dc9096 dw9116 Charge Logo
32 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
