Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Gear indicator don't work also speedometer what could be the problem?
2 Suggested Answers
ourhowse
  • 2007 Answers
SOURCE: 1997 chevy suburban speedometer not working
Check your fuses. Probably one burnt out.
Posted on Apr 04, 2013
2005 silverado gear selection indicvator doesn't display
the led in the cluster used for your indicator may be burnt out.if it is look online for speedometer/cluster repair-speedometer repair guy does a complete rebuild for $105.
Mar 05, 2014 | 2005 Chevrolet Silverado
2003 chevy silverado gear indicator lights don't work
Hi, this is a pretty common problem on these Silverado instrument clusters. We can definitely help you with that. Click here to learn more about these Silverado instrument cluster problems: Dr Speedometer Instrument Cluster Repair Speedometer Repair Guage...
Dec 17, 2013 | 2003 Chevrolet Silverado 1500
Apr 04, 2013 | 2003 Chevrolet Suburban 1500
1994 Nissan pu speedometer quit working
SPEEDOMETER TROUBLESHOOTING
Can be loose speedo wiring connectors under instrument panel or its issue with speed sensor on transmission.
I suggest you to go through help links mentioned below with appropriate solutions to confirm the problem :------
How to trouble shoot speedometer?
http://schematicsdiagram.blogspot.com/2011/06/speedometer-not-working.html
1996 fiat bravo speedometer not working?
http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
Speedometer works but odometer not working?
http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html
Speedometer runs backward?
http://technoanswers.blogspot.com/2012/01/speedometer-runs-backward.html
Warning lights on and speedometer died?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.ht
Speedometer not working on 1993 Ford F350?
http://repairhelpcenter.blogspot.in/2012/02/speedometer-not-working-on-1993-ford.html
ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Vehicles Cluster panel Not reading Miles?
http://schematicsdiagram.blogspot.com/2011/12/vehicles-cluster-panel-not-reading.html
Odometer works properly but speedometer works intermittently?
http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
These will help.
Thanks.
Feb 04, 2013 | Nissan Cars & Trucks
Speedometer and odmoeter don,t work
Either the cable got disconnected somehow behind the dash, the cable broke, or the plastic gears wore out. If yours is digital check fuses.
Apr 24, 2012 | 1991 Mazda Protege
I have a 1995 gmc sonoma and it won`t shift from first gear and the speedometer don`t work
You may have a bad Vehicle Speed Sensor [VSS] This sensor provides the information the speedometer needs to indicate speed and also supplies the transmission with information it needs to determine when to shift. If the signal is lost you can end up with the very symptoms you are having. It's usually located on the rear of the transmission or transfer case area. Hope this helps!
Nov 27, 2010 | GMC Sonoma Cars & Trucks
Speedometer and Odometer quick working. How do I
Follow the speedometer cable from the firewall, down to the transmission. It should bolt in the transmission, remove the cable from the transmission, and turn the gear to check to see if speedometer is working, if not, it's most like the speedometer head unit.
Mar 15, 2010 | 1990 Geo Prizm
Dead and Alive Speedometer and Odometer - 1998 Honda Civic
if both go then its the sensor ,but if car is a 98 then it could be a cable or a speedo cable crive worn out
Jun 29, 2009 | 1996 Honda Accord
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
12 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
