Question about Hoover S3765-040 WindTunnel Bagless Canister Vacuum
Howdo i access the beater bar - Hoover S3765-040 WindTunnel Bagless Canister Vacuum
My Dyson vaccum leaves a row of multiple lines on my plush carpet. I've never had s vaccum leave more than the two wheel lines. I called customer service and they had no solution for me!
It's the beater bar brush. Turn it over and use a screwdriver or knife, and run it the full width of the beater bar to remove the hair and string and other debris that get wound up on the beater bar-NOTE you do NOT have to remove the beater bar or take apart anything. As long as the beater bar spins, and there are no missing sections on the beater bar- this will work. Beater bar could also be worn down- be sure that the bristles extend past the bottom of the vacuum- ALWAYS DO THIS WITH THE POWER OFF
May 03, 2017 | Dyson Vacuums
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Installing new belt
+>> Unplug the mains lead from electrical socket <<+
• Turn cleaner over in flat position.
• Release lower plate by rotating the 3 lower plate latches to the UNLOCK position.
• Remove lower plate and remove any dirt that may exist in belt area.
• Remove beater bar by gripping the belt side of the beater bar and carefully lifting it out.
• Remove worn or broken belt.
• Clean beater bar and the end caps.
• Loop new belt around motor shaft and beater bar belt groove.
• Reinstall the beater bar by inserting the end cap of the beater bar to the slots at both ends of th beater bar.
• After reinstalling the beater bar, turn it by hand to make sure that belt is not twisted or pinched and that all rotating parts turn freely.
• Reinstall lower plate by hooking front end of lower plate into slots on front of nozzle.
• Press lower plate onto nozzle and secure by rotating the 3 lower plate latches to the LOCK position.
Jan 12, 2013 | Panasonic Mc-Ul594 Eco Max - Bagless...
Beater bar not working on newer ball pet unit
HighnTools posted this solution some time ago. I think it can help you solve your issue.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
Aug 29, 2010 | Dyson DC15 All Floors - The Ball Bagless...
The beater bar doesn't move when you push the vacuum. If you lift the vacuum while it's running, it's going like crazy!
replace the belt, it is so stretched that it is slipping on the beater bar when it comes in contact with the carpet. it takes the 38528-040 belt. i think its 5 screws on the bottom to gain access to beater bar and belt.
Jan 05, 2010 | Hoover U5262-900 / U5260-900 / U5266-900 /...
How do yu change the belt
Hello. W/D here.
On the baseplate that surrounds the beater bar, you'll see three large plastic screw heads. Turn these and youll feel the plate loosen. Raise the plate from back to front; it hinges toward the front. This gives you access to the beater bar. Remove the beater bar, making mental note as to how it comes out. You want to pay attention to the ends so you can get it back in easily. Remove whatever remains of the old belt. While you have it opened this far, inspect the suction cavity behind the beater bar; this is where they are most likely to stop up over time. Also take a moment to inspect the beater bar and remove the things that tend to wind up on the bar and at the ends. Slip your new belt over the motor shaft, and then slip the beater back under the belt. It will be tighter going back with the new belt. While the belt is on the motor shaft and the beater bar, slide the beater bar back into the sockets of the vacuum, and replace the base plate.
That's all there is to it!
Best regards, --W/D--
Aug 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Howdo I replace dyson belt??
Replacing the belt on the DC-17 is not complicated at all. Once I understood how, the process took about 5 minutes. My best suggestion is to call Dyson and they will quickly and cheerfully walk you through it without making you feel stupid. Here is what they told me: 1. Remove the bottom plate that covers the beater bar, using a flat head screwdriver; pull the beater bar out so that it is only attached by the belt. 2. Use the flat head screwdriver to wedge the belt off the beater bar. It takes a little bit of wiggling, but it is not difficult. 3. Once the belt is free of the beater bar, use the screwdriver to unhook it from the gear that is attached to the motor inside. 4. With the new belt, repeat the steps in reverse, hooking the new belt onto the motor gear, over the beater bar, etc.
Apr 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
There is suction but no rotation of beater bar
replace the drive belt.
turn the vacuum over. take the buttom plate off, you can access the roller (beater). there should be a belt attached to the roller and the motor shaft.
Apr 14, 2009 | Vacuums
Beater bar on Dyson upright won't turn when handle is lowered
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Hoover S3765-040 WindTunnel Bagless Canister Vacuum Logo
10 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
