Question about Ovens
Ge microwave jes738wj02 number pad wont work - Ovens
2 Suggested Answers
emissionwiz
  • 75822 Answers
SOURCE: What is the power rating of ge microwave model jes738wj02
this is a 700 Watt Microwave
Posted on Jun 11, 2009
I have an error code on my GE Microwave JK5000DK
you probably need a new microwave or try to unplug it or you can probably take it to get someone to fix it for you
Mar 11, 2016 | GE JK5000DFBB 27" Built-In Single...
I have a GE microwave/convection oven that the lower oven wont heat, fan comes on top microwave works but the oven wont heat
First reset your breaker, then check your wiring in the back of the oven. You may have just a wire loose.
Feb 24, 2013 | GE Profile JT965 Electric Double Oven
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    I have a GE Spacemaker microwave with a F3 code.
    The F3 means Key panel (touch pad) shorted. This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
    Nov 25, 2010 | GE Ovens
    F3 Code on microwave
    You have a shorted touch pad.. here is a link for a replacement.. http://www.pcappliancerepair.com/newfindform.phpIf you open up everything and examine the touch pad, you may see something that is causing the short and fix it, oherwise, you'll have to remove and replace it.. Hope this helps..
    Jun 12, 2009 | GE Profile JTP18 Electric Single Oven
    I keep getting a f 3 on my microwave , and it works when ever it feels like
    Hi, this code represents a Key panel (touch pad) that has shorted.
    This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad) in this case. this will fix this issue.
    May 18, 2009 | GE Ovens
    Need exact model No for JKP85 Double Oven
    unfortunately there are hundereds of ge microwave/oven combs that start with jkp85. do you know what part hes looking for? some parts are more common than others. i have many sources for part number if i know what he needs i can try to give you the number
    Nov 25, 2007 | GE JKP85 Electric Double Oven
    Ovens Logo
    20 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
