Question about Kenmore Freezers
Kenmore 253 Freezer specs
  • 62 Answers
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Posted on Jan 06, 2008
larryyb
  • 291 Answers
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Posted on Jul 08, 2009
Controlfrk
  • 304 Answers
SOURCE: Kenmore 253 9280413 freezer keeps running
The coils are embedded in the outer walls and will make the cabinet feel warm outside when the compressor is running. It needs about 4 inches of clear air space around all the outer case walls to properly get rid of its heat. If you have items stored too close to the outer walls they will act as insulation to keep heat from being dissipated. This can cause long run times.
A unit that has lost freon gas due to leakage, while unlikely, can also extend run times. Normal temperature should be about Zero when the dial is set to halfway.
Good Luck
Posted on Sep 17, 2009
Sea Breeze
  • 4654 Answers
SOURCE: need a manual for 253-9284215
The first three number are who made your refrigerator, Gibson (Frigidaire) Below are the model numbers that the user manual falls under, Click Here=> 253.9284215
KENMORE Upright Freezer Model: 25321711103, 216769200, 25321402101, 25321741102, 25329201002, 25321402102, 2539280415, 2539287215, 25321041100, 25321201102, 2539280214, 25321411100, 25321211101, 25321421104, 2539284215, 25320211002, 25321111103, 25321421101 If you have questions please let me know, Thanks, Sea Breeze
Posted on Oct 06, 2010
TerryTown
  • 292 Answers
SOURCE: what is the cu.ft. for Kenmore Freezer Model
The 3rd number after the 253 indictes your cu. ft. so the 3rd number on yours is 8, that means yours is an 18 cu. ft.
Best wishes,
TF
Posted on Jun 03, 2011
Looking for the start up surge for my kenmore freezer 253. I would like to purchase a generator and want to make sure this freezer would operate.
At the peak power usage time..compressor start up it may reack 11 amps..when calulating that it is a max of 1300 watts..so a generator of 1500 or more should work fine
When running after start up is usually about 500 watts
Gene
Aug 26, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
I would like to download a manual for Krnmore freezer 253. I tried to defrost, water came out of the bottom, not the designated spot. Jackie
The defrost drain is clogged in your Kenmore freezer .Due to this water is coming out of bottom.-------- The drain hole needs to be cleared.--------You can pour hot water to melt ice around drain . To see where the drain hole is located, and to get the manual, click the link below:--- http://technoanswers.blogspot.com/2011/08/kenmore-freezer-253-nor-draining-water.html ----------- This will help.Thanks.Helpmech.
Aug 03, 2011 | Kenmore Freezers
What is the cu.ft. for Kenmore Freezer Model number 253-21201102
Best wishes,
TF
Jun 03, 2011 | Kenmore Freezers
Need a manual for 253-9284215 Kenmore Upright Freezer
Oct 06, 2010 | Freezers
What should the tempurture control on a 13.7 cu. ft. Kenmore upright , model 253 214 21101 freezer be set at when 3/4 to full be set at?
you will have to play with the adjustment until you get into its range. the load has alot to do with the box temp. I suggest getting a thermometer and try setting the temp to @20-25 degrees and see if that helps
Nov 26, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Jul 02, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
May 30, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
FREEZER ALARM WILL NOT SHUT OFF
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
May 11, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
79 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
